Question about Whirlpool Refrigerators
Hello, I have a Whirlpool side by side refrigerator, Model number: ED5FTGXKQ02. I am having a problem with the ice maker. The water drips out of the water chute into the ice tray and all down the back of the freezer. It makes solid ice chunks so that we are unable to use the dispenser. I do not know what part I need to replace. Can you help? Thank You Susan Miller
    President:
  • 1,218 Answers
Good day,
The primary problem is the water valve in the bottom back of the machine not shutting down completely after a fill cycle.
This dual valve is non repairable, and you will need to replace it with a new one.
They are available at most all appliance parts houses.
Also, it would be wise, to remove the ice maker (3 screw or clips and an electrical plug, and make sure the fill tube is in good shape and not iced up.
With the ice maker removed, press on the fill tube going to the rear of the freezer to make sure it is properly seated.
Posted on Aug 05, 2010
GS6SHEXNL Ice maker dripping water
Replace the water inlet valve assembly. It has a stuck solenoid. Here is the part to order.
Dec 03, 2012 | Whirlpool GS6SHEXNL Side by Side...
Whirlpool side by side ED5FTGXKQ02 ice maker very slow making ice,replaced filter,I'm not using that much ice,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making any ice.
Hello there:
here is a couple of things to check ok
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 23, 2009 | Refrigerators
Water in ice maker drips
The cause of the constant drip is the inlet valve. Since the ice-maker water doesn`t travel through the filter but directly to the ice-maker, the valve must be faulty to allow water to travel through the valve when it`s not energized.
The valve part number most common for your type of fridge (manufactured by Whirlpool) is W10247725 and retail`s around $25-$30US.
**If you decide to service this on your own remember to unplug the unit and shut off the water to the unit.**
Hope that help`s. If so please take a second to rate the solution I provided for you here at fixya.
Good luck.
macmarkus :)
Dec 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line.
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jul 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
77 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
