Question about Toshiba Axiom 60GB HDD Satellite Pro 4300, 4280, 4260 Series (AXT0760) Hard Drive
TOSHIBA Satellite Pro 4300 series 12 gb hdd Problem: I get Blue Box Error after windows Xp load screen. I try to enter in safe mode and still blue box error. Doesnt matter what i do the blue box always. Wont actually start to the desktop and wont go past windows xp load screem. Recently tried to Reinstall xp and it couldnt install right. I Tried ERD but when i tried system restore it told me to choose operating system which is windows xp but it didnt show on the list in fact nothing did. i dont want to spend 60 bucks for recovery disc so i need a solution which is very economical. Please be specific as to what i should do.
    Sergeant:
  • 150 Answers
XP is dead. Don't waste money on it. Download a free, safe, modern operating system and install that. I have an old Toshiba and it runs Puppy Linux, but you might like Mint or Zorin, or Lubuntu if it's a 32 bit system. download one or two onto flash drives or CD, and give it a spin. Puppy will run off a CD, even if your hard drive is bad.
Why Linux is Better
http://nfp.freehostia.com/jims-intro-to-linux.html
Posted on Apr 09, 2017
Benimur
  • 6966 Answers
SOURCE: I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Posted on Apr 09, 2007
mosesclive
  • 191 Answers
SOURCE: no drives found
Tour full installation guide
http://www.windowsreinstall.com/
This will help you to get you hdd and windows running.
Posted on Aug 11, 2008
kamal1984
  • 1383 Answers
SOURCE: black screen, blue box, enter password
You have to reset your bios password.
For that open back side of laptop cover then you find motherbord chipset pull cmos cell for 15 minutes so all settings are reset.
Thanks for using fixya.
Please rate solution if it helps.
Posted on Jul 22, 2009
paul7of9
  • 1189 Answers
SOURCE: Toshiba system restore help please awhyaah?
  • Hi, these are instruction to perform the System Restore; follow them carefully! You will need Disks (CD or DVD); only if you needed to Backup System Files, before restoring the system; in which you may be (prompt) to do so. So have available beforehand, at least 7ea, of (DVD-R), or (DVD+R), or (DVD+RW) @ 4.7 GB ready! *Note: It is important to make, Recovery Disks for the Computer as well, in the event of system failure! *System Restore: 1. Go, to: Control Panel 2. Click, on: System and Maintenance 3. Click, on: Backup and Restore Center 4. In the (left) Tasks area, click on Repair Windows using System Restore 5. Windows may take up to 5Mins, to Setup a Restore Point; be patience! 6. The restore Wizard 7. Use (Recommended) Restore Point. Be patience! your Computer will Shutdown, and Restart. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running! *Conclusion: "Message successfully restored, or failed to complete restore? Follow “prompt message,” for further recommendations." "Helpful Ratings Feedback is appreciated,thanks paul7of9”
Posted on May 31, 2010
bronk50
  • 27725 Answers
SOURCE: My Toshiba Satellite C645D-SP4007M was
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Posted on Sep 17, 2011
My toshiba satellite pro 4300 series wont actually start... I give my password and then a message saying : your computer is now starting . or something like that arrives. But it juste stays their... and...
Try running chkdsk from Windows Safe mode. Switch on laptop, press F8 before windows logo comes. goto safe mode. Login. Press start>run. Type CMD. then type chkdsk c: /f /r. then type exit. and restart your laptop.
Oct 06, 2013 | Fujitsu Mobile MHS2040AT 40 GB Hard Drive
I updated my toshiba l300 pslgbe's bios from the 1.80 to the 2.2, now everytime i turn my laptop on, it shows a blue screen with an error. my laptop is now completely useless
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | Toshiba Satellite Pro L300 Notebook
What's the largest capacity HDD my Toshiba 4300 can support? Also what's the max RAM it can support?
This can support up to 160 GB of hard drive and for the max RAM support it can handle up to 320 MB.
Aug 16, 2010 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Windows wont boot up when I turn on my Toshiba
You need an antivirus program to be installed after installing your operating system. Do it in safe mode. If problem persists let me know.
Jul 10, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
Hard time getting new build to boot...
sounds to me like you either have a conflict of hardware or your os windows xp wasn't meant for your hardware some manufacturers design there products now to be vista only so read you manuals and make sure of that then try reloading xp but with bare essntials to run a pc that is
Mar 15, 2009 | Computers & Internet
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Unable to open windows
try booting into safe mode (hit F8 repeatedly when you reboot until a safe mode option comes up) then if you are able to log in, go to the windows run prompt, type "msconfig" go to startup, disable all, services, disable all. reboot. see if it still does the same, if it doesn't one of those services are causing blue screen. Also try reverting to previous drivers if you did any driver updates, remove any new cards/hardware you might of installed recently.
If you can't get into safe mode, at a copy of any xp disk. boot up from it. (make sure your boot devices are set that cd rom is before hdd in cmos setup) then go to the recovery console "you press 'r' when ou have various option" type 1 for the windows, enter. enter for password unless you previously set an admin password.
Then type "chkdsk /p", let it run also type fixboot, and say yes. reboot and see if this solves your problem.
Jan 05, 2009 | Toshiba Satellite A135 Notebook
Need to format harddrive on Toshiba Satellite Pro 4300
here are a couple of links so ya can get a handle on things.... Just follow the instructions ya be all good.... http://72.14.253.104/search?q=cache:0sWcmSlxdlwJ:lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php+tutorial+to+format+laptop+hard+drive%3F&hl=en&ct=clnk&cd=2 www.youtube.com/watch?v=CEhbmJbAjPw
Aug 17, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Toshiba Axiom 60GB HDD Satellite Pro 4300, 4280, 4260 Series (AXT0760) Hard Drive Logo
335 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
