Question about HP Pavilion dv6000z Notebook
I have a HP Pavillion Entertainment PC that will not start up. Two new motherboards have been placed in it and it will still not boot up. It starts up and then just shuts down.
    Brigadier General:
  • 4,044 Answers
Ok, this is a muti step process. 1. Remove the hard drive and push the power button. When the HP screen appears enter the Bios. This is usually done by pressing ESC, Del or F1 when the computer displays the HP screen. If you get into the Bios open and insert a bootable CD/DVD close the drive door and let teh computer continue to boot. If you don't have a disk handy you can get Knoppix, a Linux OS designed to run from DVD/CD, at most used book stores for about $5. If the computer starts your problem is the hard drive. 2. Assuming the computer did not boot. With the hard drive out, remove the RAM and repeat the steps above. 3. If the computer still fails to boot remove the CD/DVD drive and repeat. At this point you can reinstall the hard drive and RAM. Your goal here is to remove items until you locate the one that is causing the problem. Since you have already replaced the motherboard a second time you are pretty sure your main board is good so it must be a different device. The most likely fault is the Hard Drive followed by RAM, CD/DVD drive, MODEM, WiFi and so forth. Once the computer boots with a specific device removed you know that device is at fault and replace it to resolve the issue.
Posted on Aug 05, 2010
  • 39 Answers
Ok not its time for diagnostics hehe XD
first plug in your laptop and remove the battery and see if that works
if not try your laptop on just the battery (if the laptop is still abel to charge it) and see if it starts
ive ran into this issue before solution: its eather the mother board (youve replaced this several times) or the processor (if this failes the computer will turn on for a second then shut off)
other options you could try is
remove the hard drive and turn it on to see if will show the HP screen (put drive back in and try agane to see if it still failes)
if your computer still failes to start
remove the ram chips from the laptop and turn it on if the lapptop stays on (if you have 2 sticks of ram) replace one stick of ram and see if it will start if not remove the stick of ram you put in and try the other stickin the same slot and try agane (do the same for the second slot) if this solves you issue its a bad stick of ram
if this is to no availe try removing the cd/dvd drive and see if it will start if not try removing the hard drive and cd drive if this dont work put them back in
try removing the wireless card/bluetooth card and try agane
if this dont work keep on trying removing different hardware and see if it works
if doing indavidiual parts dont work remove the wireless, dvd drive, hard drive and try agane
good luck and i hoe this helps you out
Posted on Aug 06, 2010
Hp pavillion entertainment pc wont power on
HP had lots of issues in the past with faulty power Jack. If you are inclined, you can also removed the motherboard and test the fuses to see if one is blown ( use a multimeter to see if there is one that does not allow power to pass thru). Otherwise you will need a new motherboard. It might also be the power button module that is not working or the cable that goes from your power button to your motherboard is either loose or disconnected. Let's go back to your motherboard if you plug in your laptop and the battery light does not come on even if battery is inserted, then the problem is with the motherboard.
May 29, 2014 | Microsoft HP Pavilion DV6276US Notebook PC
HP pavillion entertainment PC has blank screen. I
Hi there from reading your whats you wrote this tell's me that your computer screen has gone bad. Because you are using a laptop you cannot change the graphic card,for you to solve this problem you need to change the screen.
May 19, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
Have a new HP Pavilion entertainment pc with Windows 7.
I also have a HP Pavillion dv9260 , had the same problem, HP help live said the video board, which is an intergral part of the mother board is bad....burnt out...needed to replace the motherboard and they won't stand behind them...I was out of luck $400.00 to repair and stories are that it won't last long even if you do...so here it sit's basically $2400.00 dollars worth of scrap parts........
Dec 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
plz try by resitting the ram if you dont know how to open the laptop then i will suggest you to take it to repair shop.
Feb 20, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion dv6000z Notebook Logo
341 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
