Question about Car Audio & Video
Do you know where can I find a wiring diagram and the wire harness for a 28185 9BH5A car radio?
sumthin
  • 71 Answers
SOURCE: rockwood detanater amp225 wiring harness
I'm guessing here, but power is usually a red, thick wire. seldom yellow ( old Pioneer)
Ground Is usually a thick black wire.
Amp turn on blue.(thin)
If it isn't, it ought to be.
If in doubt don't try it , check with a installer.
Fuse at battery!!!!!
Sumthin
Posted on Jun 11, 2008
SOURCE: 92 240sx dash wiring to sr20 ecu harness diagram
i knw how but i dont have wiring diagram.can u send me a copy so that i can explain to u
Posted on Nov 20, 2008
godspeed808
  • 125 Answers
SOURCE: i have a orion xtr2250
for information on your amplifier including wiring schematics got to this address:
http://www.orioncaraudio.com/Support/
and enter in your amplifiers information all files are in PDF form so get adobe acrobat reader its free download at download.com
Posted on Feb 04, 2009
memturbo
  • 226 Answers
SOURCE: need wiring diagram for Gmc envoy stereo
I dont believe its used in your situation .
here is a rundown
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Mar 27, 2009
etirbynnor
  • 655 Answers
SOURCE: NEED TO KNOW WHICH WIRE ARE WHAT ON DELPHI TRUCK RADIO
You may wish to consider purchasing a wiring harness that will allow you to plug directly into the vehicle harness without tapping or splicing. Here's a link to one such item: This one appears to be for your vehicle.
http://www.sonicelectronix.com/item_5944_PAC+ADD-GM24.html
Installer.com shows the following color code for the radio and speaker wiring for the 2007 GMC Sierra.
Speakers
White: (LF+)
White/Black: (LF-)
Violet/Black: (RR-)
Violet: (RR+)
Green: LR+
Green/Black: LR-
Gray: RF+
Gray/Black: RF-
Radio
Black: Ground
Red: +12volt Acc Switched
Yellow: +12volt Battery Constant
Blue/White: +12v Remote Output (Amp Turn On)
Red/White: Reverse Light Trigger
Yellow/Black: Parking Break Trigger
Orange/White: Auto Illumination
Blue: Powered Antenna
Orange: Illumination
Brown: Phone Mute (optional)
I would recommend that you verify the speaker wires before doing any splicing.
Attach a speaker to a pair of test probes and leaving the harness in and working, probe the back of each pair as coded above to insure that they really are the correct wires. Most likely you will want to convert the rears to low-level, so start with those. Probe the Violet(+)/Violet Black(-) pair and you should get sound in your test speaker. Likewise, do the Green(+)/Green Black(-) pair.
The only other wire you would need from the stock radio for an external amp would be the blue/white turn-on lead and if your LOC has audio sensing turn-on, you may not even need that. Bring power to your amp directly from the battery (fused according to amp manufacturer recommendations) and find a ground within 3 ft or so of where you intend to mount the amp.
Hope this helps.
Posted on Mar 28, 2009
Trying to match my aftermarket radio with factory speaker wires.. BROWN YELLOW GREEN VIOLET / WHITE STRIPE LT BLUE LT BLUE / BLACK STRIPE WHITE /RED STRIPE WHITE / RED STRIPE
Greg, Check the attached links,instruction and guides stereo and speaker wiring, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WIRE COLOR CODES FOR CAR INSTALLATION
Car Stereo Wiring Diagrams and Car Radio Wiring Diagrams
https://www.installdr.com/quickwiring.asp
Car Stereo Wiring Diagrams Director
Apr 03, 2016 | Cars & Trucks
Where can I get a radio wiring diagram?
Radio wiring color codes, radio wire color codes, radio wiring diagram, radio wire diagram, radio wiring harness, radio ...‎Radio Wire Harness and Colors - ‎Install Dr: Nissan Wiring
Mar 01, 2015 | 2014 Chrysler 200
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
Nov 13, 2017 | Car Audio & Video
2002 toyota rav4, what is ACC on harness
The acc wire is the switched + on this diagram
2002 Toyota RAV4 Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Ignition Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Dimmer Wire: Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Feb 03, 2010 | Buck Toyota Rav4 2003 Stereo/radio...
I have no wiring diagram to wire it in my car
easiest way I know of solving this is get a wiring harness for the make and model of vehicle from the auto store. (walmart also sells the harness located by the automotive radios ) connect the radio harness to the wiring harness per the instructions and you should be good to go.
Jan 10, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Console wiring damaged during breakin
Here is the wiring info for your radio. I have some other wiring diagrams but did not see anything related to your ac. Hope it helps and let me know if you want the other wiring diagrams. Also once you know what these wires are then you will be able to tell what wires are not related to your radio and might be able to figure out which wires are causing your other problems?
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE(+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Amp Location MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Oct 09, 2008 | 2002 Hyundai Accent
Wiring a radio
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
here is the wire diagram for your car this should fix your problem
Sep 16, 2008 | 2002 Mitsubishi Lancer
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
