Question about Asko T731 Electric Dryer
Asko T731 Electric Dryer - where are the fuses on the back of the dryer?
  • Asko Master
  • 2,605 Answers
Welcome to Fixya.
Before starting...
**Turn off your breaker at the home service panel, it should be a 30amp switch or unplug it from the wall...safety first**
The fuses are at the back located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, reliableparts.ca etc.
Asko part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on Aug 05, 2010
Asko T731 Dryer rollers
http://www.askona.com/customer-care/resources/manuals
Sometimes there are spring clips that require a bit of prying before they pop free. Contact mfr for a parts diagram, that will show all of the parts and how they go together
Jan 06, 2014 | Asko T731 Electric Dryer
No led light how do you check fuses?
Unless im mistaken they are in the back and cover needs to come off, see this picture.
Jul 26, 2008 | Asko T731 Electric Dryer
How do i replace the belt on my asko t731
open up the back panel it is usually right ther and easy to do
Sep 07, 2011 | Asko T731 Electric Dryer
No light display
evidently. there is/are fuses on the back of the dryer, I am assuming one of those may be blown. Here is a manual I found, it does not have a wiring schematic on it, so I am assuming that Asko is the same as any other manufacture, meaning they put the schematic in the top left hand corner of the control panel on there dryers. Should be 6 screws. I hope this helps Tim:
http://dl.owneriq.net/e/e7d9f38b-5a0e-6344-6949-46091be9e970.pdf
Dec 25, 2010 | Asko T731 Electric Dryer
ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Dec 05, 2009 | Asko T731 Electric Dryer
Asko T731 sensor suuts off the dryer prematurely
you need chek are clean folow:
1-line chute assembly.
2-housing blower.
3- pipe duct .
Oct 05, 2009 | Asko T731 Electric Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Asko T731 Electric Dryer Logo
327 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
