Question about HTC G1
Everytime i press the red end button on my G1 the phone screen goes blank and i have to take the battery out and put it back in for it to turn ...how do i fix it?
Posted on Sep 04, 2010
  • 40 Answers
Do a factory reset.
Posted on Aug 06, 2010
Phone handset screen is blank. It says Searching and when I press a button it goes blank.
Try unplugging the battery inside and reconnect it and put it back on the charging stand
Mar 02, 2015 | Uniden DECT 6.0 Cordless Telephone...
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
Other than the G1 and Android appearing when my phone powers up, the screen stays blank. any ideas on what may be wrong?
Easy i just figured it out with my g1 with the same problem. The solution is this: Try taking out the battery put it back in. press and hold the power+home butto. a screen will show then press the power and home button agian. It will then give you some choices, choose wipe out your memory to factory settings and it should work after.
Apr 11, 2010 | HTC G1
Phone doesnt come on completely
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
Apr 06, 2010 | HTC G1 Smartphone
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
Phone will not shut off
take the battery out and when it turns off put the battery back in nd close it,if you want to turn it back on then press the end button.
Jun 08, 2009 | HTC Google G1/Dream Cell Phone Black...
G1 will not come on
Mine did the same thing today. Removed the back cover, then the battery - IMPORTANT - left it out for 60 seconds.
Put the battery back and pressed the red button. Works again.
Mar 28, 2009 | HTC G1
My G1 can't power on :<
sounds like the red buttons have stopped working. you can attempt to reset the phone, if that fails either the button will need to be replaced, or you can contact T-mobile for a replacement given it is still under warrenty.
to reset the phone, try this:
with it OFF press the HOUSE and the POWER buttons until the phone powers up with a triangle and a yellow '!'inside. slide open the screen and press 'ALT' and 'W' at the same time. the phone should boot up as normal. if that fails, call t-mobile 1800-937-8997 for a replacement.
Jan 21, 2009 | HTC G1
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
HTC G1 Logo
274 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
