Question about Brother MFC-290C Printer
My scanner does not connect to email . error CC3-003-00031-c0e says USB device might have stopped responding??? how can I fix this?? Thanks you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
Please open Device manager and remove all o the USB driver and click on Scan for hardware changes. When you click on that all of the usb driver will install automatically. After that Connect the saner and install the proper driver.
Posted on Aug 05, 2010
Pushing scanner button does nothing, and using software to scan results in a "no scanner" connected error message, even though it is connected and prints just fine.
Is it connected by a USB cable? Try a new data cable and swapping ports. If you have it connected to a print server or USB hub, try a direct connection. Scanners require bi-directional communication with the computer and are more likely to fail to respond to a problem that blocks the signal than the printer. Does the scanner light move and make the usual warm up sounds? Do you have the full software installed or a basic driver from the OS? Do you have the latest software installed?
Disconnect the power cord from both the unit and the wall outlet and the USB cable from both the computer and the printer. Wait at least 10 seconds before reconnecting (resets the all-in-one). Repeat the USB cable removal with the computer and the printer on. Reboot the computer (in case something is locking the scanner in memory).
Check if the scanner shows up as an imaging device. Click My Computer (in some versions of windows), Properties. Click the Device Manager tab. Open Imaging Device. Highlight the all-in-one and click Remove. Try scanning again. (This can be found through the control panel on other versions of Windows.)
I hope this helps.
I hope this helps.
Apr 25, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
LIDE 60 stopped responding
Is there a pointer system that is set to point to that device? Like the printer has?
Aug 02, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
Responding error of mouse or USB while using it?
This seems like a conflict in the drivers. Check the device manager for conflicts like a yellow esclamation mark. YOu can get to it by going to start /control panel /system icon / device manager
Mar 03, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Scanner part of my system quit working.
Hi
I understand the issue, many HP all in one printer can print, but they don't scan. you might a error message "Error occurred while communicating to scanner device..". Before we uninstall the software, we can try resetting the USB composite Devices.Just follow the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP OFFICEJET 6100.
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Please response after trying this.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dcp-115c usb cannot be found (CC027)
sure..some printers need to be plugged directly into wall socket for scanner to work..try that first..
Nov 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
Scanner Error 6
clean glass. switch off. clean the lightsource bulb. keep fingers off the glass when cleaning
Apr 17, 2008 | HP LaserJet 2840 All-In-One Printer
Error code 2019
Step 1 - Verify the scanner's power and connection
  1. Verify that the scanner is turnned on
  2. If the Check or Ready light on the scanner is flashing, click VIS1023 - Check Light Blinking on ADF Scanner for more information
  3. Check that the USB cable is connected to both the scanner and the computer
    • It is recommended that the scanner be connected directly to the back of your computer with a 6 foot or shorter USB cable
Step 2 - Redetect the scanner in device manager
  1. Turn the scanner off
  2. Click Here and select "Run" or "Open"
  3. The Windows Device Manager will open
  4. Go to "View" and choose "Show Hidden Devices"
  5. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  6. If listed, right-click on the DocuMate 510 then left click on "Uninstall"
  7. If asked to confirm the uninstall, click "OK"
  8. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner
  9. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices
  10. Right click on any instince of the scanner in this list then left click on "Uninstall"
    The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • DocuMate 510
  11. Once the scanner has been completely removed from Device Manager, turn the scanner back on
If there is no Found New Hardware message when the scanner is turned back on and the scanner is not listed in Device Manager under Imaging Devices or Other Devices, this typically means the scanner is not communicating correctly with the computer. Try plugging the scanner into a different USB port or using a different USB cable.
Jan 08, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Scanning error - cannot scan error code 2,155,0 ???
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Sep 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Brother MFC-290C Printer Logo
327 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
