Question about Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune FAV6800 washing machine overfills on the rinse cycle. Pulling the electric power does not stop the water flow. I have to turn off the water at the faucet feeding the hose. It seems to be either the valve or the pressure switch. The problem is intermittent.
  • 526 Answers
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Posted on Aug 06, 2010
Testimonial: "Excellent advice, thank you!"
  • johnatevw Aug 07, 2010
    Thank you for the suggestion to switch hot and cold water hoses. That works well. We can do laundry until the new water inlet valve arrives next week.
    Your guidance helped me solve the problem without calling in an expensive repair company. Thank you very much!
  • FAV6800A FAV9800A
    FAV6800A FAV9800A Aug 07, 2010
    John,
    Good deal….. glad to help out a fellow owner. The machine is very easy to work and on once you get a little hands on experience you will be able to handle any issue with the machine and save big $$$.
    I would estimate to have a repair company came out it would cost you around $125 plus the water inlet valve cost. I don’t think you could get out the door without spending $175
    I go by **** but as you can see this board stars out my name so I sign off with D*ick. FIXYA quit auto parsing my name with STARS…..****
    You can find me on other DIY repair forums just Google dh1200s. Shout back if there is anything else I can help you with……have a good Maytag day….:)
My Maytag FAV6800 washer hungs part way through a cycle the timer on the front display stops at about 23 on the quick wash cycle.
Sounds like a pressure switch/ chamber issue. Check the tube is clear to the drum. (Assuming front loader?)
Apr 25, 2012 | Maytag Neptune Washer
Getting dc error code in rinse cycle, 13 min.
See my Clutch Fix post. Anyone with basic mechanical skill sets can save there $1000 machine for low cost maintenance or Clutch pulley replacement.......Rich
May 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag water fill
If the only way to stop the water flow is by turning off your faucets, replace your fill valve. If you can control the flow by unplugging the unit then you have an electrical problem, causing power to get to the valve. This is highly unlikely, but possible.
Jun 02, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer Problem
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Dec 26, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
363 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
