Question about Canon PowerShot SX10 IS Digital Camera
Pictures I took in a boxing club under flourescent lighting are grainy - How do I get rid of the grainy look of the pictures
    Brigadier General:
  • 11,967 Answers
Photoshop Elements and other photo editing programs have settings to help smooth out the grain and give a softer look to the pics. Next time you are doing a similar shoot, make sure you set the white balance for the lighting available, and try a few different ISO settings to see which one gives you the best results.
Posted on Aug 05, 2010
All the pictures that I took at a cheerleading camp in an indoor football field are grainy. I had the setting on P and iso on 1600. What did I do wrong
Hi it is normal that you had setting ISO1600. If the picture come fine then something wrong. Up to 400 speed, you can see fine picture. Higher than that would come picture grainy.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
Grainy pictures and not sharp
These cameras were designed to be high sensitive to light. If the Flash is set for Auto Flash, the camera tends to use ISO 400 whether the flash is fired or not. This was done to increase the working range of the flash.
In order to change this setting please go into the Menu (Capture+ tab) and set the ISO for 64, 100 or 200 in order to reduce the graininess. However this will lead to slower shutter speeds in low light.
Jan 28, 2010 | Kodak Easyshare M381 Digital Camera
Grainy pictures
I have had this on my camera,
I took it apart and cleaned all the lens from behind and it took perfect pictures.
You best bet is to google the service manual, and see were you can go from there. if not take it to a local repair store.
Hope this helps.
Thanks
Feb 26, 2009 | Kodak Easyshare M753 Digital Camera
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Horrible indoor pictures
can i have a look at the picture please
Oct 16, 2008 | Kodak Easyshare M753 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Grainy Pictures
This camera with the ISO set to 100 ASA, the electronic zoom turned off, and with the mode on Automatic "A", should take very good pictures.
I would give the camera to the manufacture for service, and include some samples of what the results are. It would be recomended to do this while the camera is under warranty.
Jerry G.
Apr 27, 2008 | Olympus Stylus 820 Digital Camera
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
Grainy Photos using Natural Light
Sounds like the 'shutter speed' as it was called is too fast.
Jun 23, 2017 | Nikon Cameras
Canon PowerShot SX10 IS Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
