Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
My headset is constantly loosing connection to my phone. I can faintly hear people but they cant hear me. It works fine when I take it out of the charger and put it on but in less than 5 mins the issues start.
Cant hear caller on nokia 300
Ontact the supplier/seller ,sounds faulty to me ,only a week old dont mess with it should still have warranty.
Jan 13, 2018 | Nokia Cell Phones
The headset symbol is showing on my screen on my N97 and I dont have a headset connected at all, when people ring me they can hear me but I cant hear them because apparently my phone thinks there is a...
The headset jack is jammed.
Try blowing some compressed air in there and also insert a headset plug and wiggle it about to see if it knocks the stuck bit loose.
Mar 05, 2011 | Nokia N73 Cellular Phone
Cant hear on my blue parrot headset. it was working fine then just stopped. its showing that my phone and headset is connected.
try this: have both on but not in use,plug the charger in for 10 secs only then unplug, watch lites go from red to blue then flashing just blue at a rate of 1x per second. that resets it. worked for me.i called the company
May 17, 2010 | VXI Corporation Blueparrott B250-XT...
Cant hear calls, people cant hear me
Check your handset Settings to ensure that you are selecting your telephone default internal sounds devices instead of an external devices (such as your headset, or bluetooth for that matter).
Dec 24, 2009 | Samsung Rant Cell Phone
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
L9 headset
turn up the volume on the left hand sign on ur phone
loook for the code at the back on ur fone and try repairing it..
hopefully it will work :)
May 10, 2008 | Motorola Radio Communications
Bluetooth won't work on samsung t 809
So your phone can connect to it but just can't hear? Can other hear you? What is the brand or model of your headset?
Mar 11, 2008 | Cell Phones
Headset not working
The fine wires in the cord casing do break easily. If your RJ9 connection is loose, then the brass contacts are not making good contact inside the T10 base. Not many options, unless you can get the RJ9 clip repaired, but to get a new system.
Good luck from Headsets Direct!
Dec 16, 2007 | Plantronics (45647-04) for S10, T10, T20...
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
13 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
