Question about Garden
My mower runs rough revs up and down then will die... coughs out smoke from the carberator... will comtinue to run reving up and down if I tilt it back on the rear wheels Murray select 22 mod. #22415x8c 4.0hp motor manuf. date 01318
Take the bowl off the carb and see if the float isn't sticking sounds like it is getting to much fuel.
Posted on Aug 07, 2010
Briggs stratton problems
Is there a screw setting on the carb? if so turn it to the left and this allows more fuel to make it run better. Turn a little at a time and you will hear the engine rev better.
Jul 19, 2014 | Briggs & Stratton Garden
Corsa 1.3i over revs
run fault codes and check for MAF/MAP sensors and HO2S and HO2 sensors.
Feb 18, 2014 | Cars & Trucks
Engine runs rough revs
whats the mfg and model #
sometimes tractors that sit for long periods get build up in carberator that makes starting tough and engine rough running
Nov 11, 2013 | Craftsman Garden
I have a cub cadet LT1018 with 800 hrs. The engine, B&S 18.5 hp, started running rough and sputtering while mowing. Disengaged PTO to return to garage - mower died. Cleaned air filter and restarted,...
Sounds like water in your carberator. Remove the bowl and check for dirt and water, drain some gas from the tank into a bowl and check for water in the gas. Remove air filter housing and lubrcate all of the carberator linking with a product such as WD-40. Reassemble everything and start again. While you are at it check the spark plug too.
Oct 20, 2017 | Cub Cadet Garden
32LC trimmer will start and idle but bogs when trying to advance throttle. I can not get it to rev up. I put fresh fuel mixture in it, changed the spark plug, cleaned air filter, even purchased a new...
Did you try cleaning the carburetor before installing it? It may have factory oils and greases that are obstructing fuel flow.
If it runs fine at idle but bogs down when reving, then you are either not getting enough air or not getting enough fuel.
Have you notices any black smoke from the exhaust when you try to rev it? If so then you are running too rich and aren't getting enough air. You may want to check the path of air travel for other restrictions.
Jun 07, 2011 | Husqvarna Garden
Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Sep 06, 2009 | Garden
I have a toyota and my car is parked up for a few hours when i go
Does it run rough when stalling at 1000rpm or does it seem like the rev limiter is taking over (just revs and stope). If running and just stopping you man wanna have your ECU reflashed (common problem). If running rough you may have some other issues and need a diagnostic. Try going to your local auto parts store and having a code scan (its free) and see what codes if any are present.
Sep 02, 2009 | 2001 Volvo S40
Car kangaroo jumps
replace IAC (idle air control valve) and replace coilpack,wires,plugs that should solve your jumping and reving.-z i have one i replced all above and have no problems scince
Jan 29, 2009 | 1994 Ford Escort
Starts on first pull. Runs about 30 seconds and dies.
Found the air filters on both mowers were so saturated with oil there was not enough air getting to the carburetor. Cleaned the filters first with dishwasher detergent and hot water, dried them, then soaked them in aclcohol to remove more oil. Dried filters, installed on mowers, and both mowers now run fine.
Jan 17, 2009 | Garden
Garden Logo
647 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
