Ac unit does not work .replace unit but does nt work
    President:
  • 1,515 Answers
Hi, it sounds as though you have a window or wall type unit? If so, and the new one doesn't work either, have you checked to see if you have a power problem? The other or older unit may have tripped the breaker or the plug where your cord goes may have a bad wire, a burned off one if it is aluminum, as they get hot and will loosen up and burn off. I would have to say its a power problem for sure if the new unit doesn't work either. Can you check this and get back to me to tell me what kind of a/c you have? This would be helpful if its not a power problem, which I believe it to be. You can plug a extention cord into a different socket and plug it in to see if that plug is dead also. I think you will find the power problem. Please rate me if you will and be kind as I know you will. Get back to me as I have all of your information I keep on file for my solutions and let me know the outcome.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 05, 2010
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
I recently bought a 99 chevrolet cavalier LS 2.2 from the time i drove it home it started heating up,so i replaced the thermostat filled it with anti freeze and it still guage read 195 degrees and fan...
If there isn't actually any coolant dripping out of the engine, or rad, or hoses when it is sitting, either running or not, you most likely have a blown head gasket. The easiest way to check is, when it is cool, remove the radiator cap, and start the engine. If bubbles are constantly rising to the top of the rrad, your head gasket is gone, and i can almost guarantee you that is the problem. Sorry.
Aug 22, 2011 | 1999 Chevrolet Cavalier
Onida split ac show only f8 in display. how to slove the problem
That code is usually a result of a leak in the system and the unit being low on charge...find/fix the leak and recharge the unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble -Review the Possibilities
heatman101
Jun 21, 2011 | Heating & Cooling
I bot a hp mini laptop recently.. ws working well..bt sddnly it ws nt chrgng ystrday and showed cross sign over battery in control panel.. why is it nt chrgn and wht to do?
If the laptop is still working when it is plugged in , then the ac adapter is good and the battery is just bad. If the laptop will not work when it is plugged in then more than likely the ac adapter is bad.
Oct 27, 2010 | HP Mini 1000 Netbook
The 24v transformer died in my Pentair MiniMax NT. How do i get a replacement? It is a Bestwill Model BC091802 Thanks, Patrick
To replace the dead transformer use a Packard Inc. transformer part number PF42440. This should be available at most heating/ AC companies and if this model is not available cross reference it to a model they sell. The installation is simply install the connectors from the heater, mount it, and plug it in. The installation took about ten minutes and the unit works fine with this transformer. There is nothing special about the Minimax transformer and the cost was $15.00 for the replacement unit.
Apr 01, 2010 | Pentair Minimax NT Heater
How do I test my spark unit on a 1998 Honda NT 650? My pump works but it is not getting power. My pump relay works. Any suggestions?
Easiest way id to take the unit to a honda dealer they can easily test it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 03, 2009 | 1991 Honda NT 400
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
Oct 05, 2007 | SI-TEX MAX10 NT GPS Receiver
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
