Question about Jenn-Air Refrigerators
Model JCD2289AEW - Maytag Jenn-Air Side by Side refrigerator; serial number 11844676wu: trying to replace the Dispenser Control Panel. I have the replacement ready. I have removed all the screws to pull out the housing. Do I pull the rubber actuator pad off? Is there a screw behind it? I cannot seem to get it to release. Any info would be appreciated. It has been 7 years since this part was replaced. The repairman said it was easy enough for me to handle it next time. I just cannot remember how he released the housing in order to get the old control panel out. Thank you, David McCorkle dmccorkle6245@yahoo.com
5 Suggested Answers
  • 1462 Answers
SOURCE: How do I remove cover from fridge temperature control panel?
lever off the thermostat knob and you will often find fixing screws behind. also, fixing screws are often hidden behind little blanking plugs which lever out to expose the screw head
Posted on Jul 21, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Posted on Sep 26, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Amana Refrigerator Model ABB2222FEQ Control Panel Cover
Yes, I can help you and send you the service manual also, Thanks, Sea Breeze
Posted on Jun 16, 2009
rohntech
  • 422 Answers
SOURCE: Freezer not cold enough to
The door magnet must be tightly seal, check the door gasket for some deformities. If there is, that really cause the freezer not to be cold enough. It would mean, the cold air is flow outside hence not penetrating the inside so the food and drink heat are not absorbed. You can adjust door gasket using screw driver.
Thanks for asking.
Posted on Jul 04, 2011
How much is the Jenn-Air Model JCD2289AEW worth today?
just depends on the age, location and what condition the machine's in. You could probably get over a thousand easy for it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Jenn-Air JS42SEDUDB Stainless Steel Side...
Freezer not cold enough to keep food frozen. The door does not have a tight seal . It is a sidebyside , Jenn-Air model number JCD2289AEW.
Thanks for asking.
Jul 04, 2011 | Jenn-Air Refrigerators
I have a Jenn-Air side by side fridge/ freezer (JCD2289AEW) the freezer is working fine the fridge is not cooling down, I did hear what sounded like a fan rubbing against something prior to the loss of...
Most likely the freezer is icing up and the fan is rubbing on the ice. there are 2 possible problems 1. the defrost thermostat is bad 2. The heating element is bad . It's most likely the first so here is a link on hoe to replace defrost thermostat./ http://www.youtube.com/watch?v=z-h541_14ZE
May 16, 2011 | Jenn-Air JS42SEDUDB Stainless Steel Side...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Water and ice not depsensing...light "stuck on"
Most likely the problem is a bad dispenser control board. For a more accurate answer, I would need the model and serial number of your refrigerator. You can find the model number in the fresh food compartment in the top right or in the upper section.
Post it back
techgirl26
Sep 13, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerator not working properly
dispenser board needs to be replaced. There was a recall on certain Ice 2O units. Call Maytag and see if your unit qualifies.You will need model and serial number.
Jul 23, 2008 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
73 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
