Question about Axion AXN-8701 7 in. Portable TV
Plugged in, cable connected, turned on, says "No Signal"
  • 5,521 Answers
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Posted on Aug 05, 2010
Vizio tv no signal
Vizio's have an input button on the remote. Be sure to check all of the connections listed. It is important to know how your cable plugs into your TV. I.E. Cable, HDMI, etc. looking at where it is plugged into on the tv will help you to ensure that you have the correct input chosen. Also be sure your cable box is turned on. If it is off or unplugged your vizio TV will not register a connection.
I hope this helps!
-Rogue
Jan 01, 2014 | Televison & Video
I have a Magnavox 15MF400T/37 LCD TV operating with a cabel connection. As of yesterday it has no functions but when I turn it on I get a message that says Attention No Signal. I have checked the cable...
Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
Jul 21, 2008 | Televison & Video
What do if my lenovop pc showing only not connection ?
Check if your LAN-cable is plugged into computer and in the other end of cable to wall-outlet/adsl-modem/some router /switch
If the cable is connected is the indicator light on both ends.
Thunder and lightning could have a electrical surge in the internet grid?
Mar 27, 2012 | Lenovo Computers & Internet
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Sub doesnt do anything while plugged in ( Sunfire mk II)
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sunfire True Sub MK II Subwoofer
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
EN9250 worked graet 20 minutes ago. Unpluged it to move computer- Plugged it right back in and now no signal. I have checked all connections and still no signal
Make sure the cable is plugged into the video in. Shut down the computer and unplug it. Unplug you monitor again and also check conections by removing the cable make sure no pins are bent on the monitor or the conection to the computer. Plug all back in. Turn the monitor on first and then the computer. I hope this helps. If not let me know I will need so more info. Good Luck.
Jan 15, 2009 | Computers & Internet
Problem with the wireless
chech your lan settings
May 04, 2008 | Computers & Internet
Axion AXN-8701 7 in. Portable TV Logo
287 people viewed this question
Top Axion Televison & Video Experts
Steve
NOEL
NOEL
richie46
Are you an Axion Televison and Video Expert? Answer questions, earn points and help others
