Question about LG L226WTQ-BF Monitor
I have an LG Flatron L226WTQ-SF and my monitor has some "shadowing". If you need more infos I can send you some pictures.
  • 225 Answers
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Posted on Aug 05, 2010
  • isti_sunyi Aug 07, 2010
    I have both D-DVI and D-CVDV inputs and I had replaced the cable and the same problem appeared so I don't think that this is the problem.
  • Dimitar Todorov Aug 07, 2010
    Send me pictures to totomitak@hotmail.com
Monitor sleep problem
This type of problem is usually caused by a failure of the filter capacitors on the power supply board. The LG L204ws uses the AIP-0156 power supply which is the same board used in many of the LG monitors that were sold around the same time. Here is a link to a repair guide for the LG L226wtq model that used that board. The repair guide as pictures and videos showing how to open the unit and check the filter caps. There are parts lists showing what needs to be replaced too.
http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/
I hope this helps,
BuddyMc
Dec 01, 2012 | Computers & Internet
Hello my flatron l206wtq-bf doesnt work the light of power flash blue and the monitor doesnt open do you have a solution for me thanks
Your unit has a power supply that has failed. When the power board starts failing you may get a wavy display, it may be slow to show a picture or you may just get the flashing power button light that you have. The problems are caused by parts called capacitors that have bulged and failed. Here is a link to a repair guide for the LG L226 that uses the same power supply board as your unit.
The dis-assembly information is almost the same to.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 01, 2011 | LG FLATRON L206WTQ-BF Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
I need window 7 driver for a lg flatron monitor L226WTQ-SF Cheers
There is no need to install any driver for the monitor as the inbuilt drivers always work with all operating systems and windows 7 have thousands of drivers inbuilt.
Mar 05, 2010 | Computers & Internet
I have a l226wtq-sf monitor, is there a 64bit windows vista /7 driver?
L226WTQ monitor won't turn on after 3 min.
Hi, I have this model and defective as a power problem, so I ordered capacitor package to solder, but the board was a little different model with the posted picture. As my poor knowledge, defective caps look fat so easily identifying its problem, but they were looked good. Anyway I soldered 3 of them matched with the procedure, but it kept on for 3 min then had gone and never turned on. After a while, it could turn on for an other 3 min.
Please help me~~~!
Feb 18, 2010 | LG L226WTQ-BF Monitor
Can't get picture to fill screen on a W2242OP LG Flatron
Downloaded manual from LG website and followed instructions to reset monitor.
Nov 05, 2009 | LG Flatron W2242P-SF LCD TV
My screen on my Lg Flatron L226wTQ=bf went white. I tried rebooting it a few times and have also tried uplugging it. I have plugged in my old monitor for now which is working very well. Can you help me?...
Its either going to be the lcd or the inverter is bad. Keep in mind that the cost to repair the monitor is going to be more then its worth. Also make sure that your pins on the vga cable are nice and straight, bent pins can also cause this type of problem as well.
Jun 12, 2009 | LG 22" FLATRON LCD Monitor
LG FLatron 22 Inch : model number (L226WTO - SF)
It's problem in properties of monitor.I have LG l226WTQ and i'm having home bad things like http://img.youtube.com/vi/MzQtRBtrvc8/default.jpg
I don't know how to solve this :'(
Dec 02, 2007 | LG Flatron L2320A 23" LCD Monitor
LG L226WTQ-BF Monitor Logo
342 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
