Question about Samsung S860 Digital Camera
I need help with my Samsung s860 digital camera...I found it in an abandoned house but its in excellent condition...i just needed to add the memory card and batteries...so thats exactly what i did...but now it wont turn on at all only the yellow light appears and nothing else...not even the screen.
    Brigadier General:
  • 11,967 Answers
"excellent condition"? Really? Yet, it doesn't work. That's probably why it was abandoned along with the house.
Posted on Aug 05, 2010
Software for samsung S860 digital camera
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Apr 20, 2013 | Samsung S860 Digital Camera
Memory card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 08, 2013 | Samsung S860 Digital Camera
My s860 samsung camera is not readin the battries
There is no issue with the battries, the problem is with the lens which is not opening, So that you need to repair the optical unit or to replace it. For both condition you should contact any repairman nearby.
Thanks
Feb 25, 2012 | Samsung S860 Digital Cameras. 8-megapixel...
I have a samsung s860 camera does the camera save photos in memory or only in the card
Hello Marina Mae,
Samsung S860 has 11 MB internal memory.
I hope this helped you.
You can rate my answer if you appreciate it.
Thanks!
Oct 26, 2011 | Samsung S860 Digital Cameras. 8-megapixel...
From camera to memory card
If you mean getting the internal memory pics to the memory card, there should be an entry for "copy" in the menu which should offer you the choice to copy the internal memory to the memory card.
Feb 25, 2010 | Samsung S860 Digital Camera
Memory card type for Samsung S860
The S860 can use any SD or SDHC card.
Jan 13, 2010 | Samsung S860 Digital Camera
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
I have a samsung s860. I put a brand new memory card in it and it says it is locked.
on the SD or memory card there is a part that you can move/click on the side - move the position and see if that helps fix the issue. I had that problem with my SD card and figured it out.
Jan 25, 2009 | Samsung S860 Digital Camera
Samsung S860 Digital Camera Logo
150 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
