Question about Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 has "paper out" light blinking. Error message says "Maintenance Required 0040". Does anyone know what this refers to and can I do the required maintenance? Thanks.
  • 4,472 Answers
It sounds like the cleaning unit has reached the end of its life. Have you tried updating to the latest firmware yet? You can find it on epson's website here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14412&prodoid=19302856&infoType=Downloads&platform=All
If you need further assistance let me know.
Thank you,
Lee
Posted on Aug 05, 2010
Maintenance request 0040 is showing on our Epson stylus pro 7800. Could you please reply with the solution? Thanks.
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Oct 27, 2010 | Epson Stylus Pro 7800 InkJet Printer
Maintenance required 0040 code
Hello.
Your error code means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Hope this helps.
Nov 14, 2009 | Epson Stylus Pro 9600 InkJet Printer
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
Turn off printer
Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed
Turn on printer
Release buttons
Hidden new menu appears
press DOWN, “CLEAR COUNTERS” option should appear
press RIGHT
press UP, “MAINT TANK” should appear
press RIGHT
press ENTER (CUT/EJECT button)
Turn off printer.
Jul 17, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Service required error 0001002d
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Feb 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer is displaying message maintenance req 0040
refix the ink cartridge after clean .it seems like your ink need replacing.
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
308 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
