Instrument gauge cluster does not light up - Computers & Internet
    Genius:
  • 1,035 Answers
Hi. Are you refering to the gauge of your car?
Posted on Aug 05, 2010
1998 chevy cavalier where is the BCM (body control module) located?
You have no idea what your messing with . Theft light on , DTC'S - diagnostic trouble codes stored . Before you start replacing BCM an making matters worse ,do yourself a favor an take it to a qualified repair shop .
The powertrain control module (PCM) communicates with the instrument cluster using serial data over the UART serial data bus, CKT 800. When the instrument cluster determines a Pass Theft condition, the instrument cluster sends a coded password to the PCM. When the instrument cluster receives the correct password, the PCM enables the fuel injection system in order to allow the vehicle to operate normally. The PCM may allow the vehicle to start and stall quickly during a failed theft condition.
The Passlock™ lock cylinder is a locking cylinder that turns a rotating magnet past a stationary hall effect sensor. The rotating magnet creates a resistance code (R-Code) that the cylinder sends to the instrument cluster. The Passlock™ lock cylinder interfaces with the instrument cluster through a 3 wire connection. The 3 wires have the following functions:
• Power
• Ground
• Data
The THEFT SYSTEM indicator will not light under any circumstances.
Replace the instrument cluster.
For Chevrolet vehicles, refer to Instrument Cluster Replacement .
For Pontiac vehicles, refer to Instrument Cluster Replacement .
Multiple indicators light continuously.
Test for a loss of serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1021 sets.
The DTC indicates a loss of powertrain control module (PCM) serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1022 sets.
The DTC indicates a loss of SIR serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1023 sets.
The DTC indicates a loss of ABS serial data. Refer to Data Link Communications System Check .
Instrument cluster DTC B1011 sets.
Refer to DTC B1011 Passlock Cyl Data Shorted This Ign Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1012 sets.
Refer to DTC B1012 Passlock Bad R-code This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1013 sets.
Refer to DTC B1013 Passlock Bad Timing This Ignition Cycle in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1014 sets.
Refer to DTC B1014 Passlock R-code Unprogrammed in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1015 sets.
Refer to DTC B1015 Passlock Cluster Fail Enabled in Instrument Panel, Gauges and Console.
Instrument cluster DTC B1017 sets.
Refer to DTC B1017 Passlock R-code Learn Failed in Instrument Panel, Gauges and Console.
The indicator flashes and no instrument cluster codes are set.
So , do yourself a favor an have a qualified repair shop check it out .
Jul 22, 2016 | Cars & Trucks
The red arms on the gauges do not light up on a 2004 saturn l300
All of the instrument cluster functions are handled inside of the cluster. So for just the gauge needles not lighting up, you will need a replacement instrument cluster.
Mar 01, 2015 | 2004 Saturn L300
After disconnect and reconnect the battery of my opel antara, the indication of odometer displays only 888... for all indications. How can i reset it?
This solution will be of great help to you,even in the case of future or other dashboard problems;
Instrument cluster consists of electronic analog gauges, various warning lights, and optional tachometer. Vehicles equipped with tachometer have an electronic vacuum fluorescent transmission range indicator (PRND3L),odometer and trip odometer display. Vehicles without tachometer are equipped with a cable-operated transmission range indicator.
Instrument cluster is equipped with the following warning lights:
Battery voltage.
Cruise (speed control).
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Low windshield and washer level.
Traction Control.
The Body Control Module (BCM), which receives input from various sensors, sends display information to instrument cluster and operates gauges. Instrument cluster incorporates a self-test diagnostic feature to identify electronic problems. BCM, Powertrain Control Module (PCM), and Transmission Control Module (TCM) are continuously monitored by the diagnostic system.
SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON position. Continue to hold TRIP and RESET buttons until odometer window displays CODE (approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
CodeDescription
110.......Cluster Memory Fault
111.......Cluster Calibration Fault
905.......No CCD Bus Message From TCM
921.......Odometer Fault From BCM
940.......No CCD Bus Message From PCM
After diagnostic code display ends, instrument cluster will go into each of the following tests in order:
Dim test.
Calibration test.
Odometer segment test.
Electronic Transmission Range indicator segment test.
Dim Test
CHEC-0 will be displayed in odometer window. Instrument cluster will dim Vacuum Florescent (VF) display. If VF displays do not dim, a problem in instrument cluster exists. See BODY CONTROL COMPUTER TESTS in BODY CONTROL COMPUTER article.
Calibration Test
CHEC-1 will be displayed in odometer window. Each of instrument cluster gauges will move sequentially through each calibration point. See GAUGE CALIBRATIONS table. If gauge needle is not calibrated properly, a problem in instrument cluster exists.
Odometer Segment Test
CHEC-2 will be displayed in odometer window. Each segment of odometer will light sequentially. If any segment does not light, replace instrument cluster.
Electronic Transmission Range Indicator Segment Test
CHEC-3 will be displayed in odometer window. Each segment of electronic transmission range indicator will light sequentially. If any segment does not light, replace instrument cluster.
Sep 10, 2012 | 2007 Opel Antara 2.0
My nissan Almera S reg has no side lights or dash lights.All fuses seem ok.
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Sep 10, 2012 | 2005 Nissan Almera 1.5
Where is cluster for speedometer lights
The "cluster" means all of the things you see under the plastic cover in front of the driver, the 'gauges'. The term is a reference to the 'instrument cluster' including speedometer, tachometer, fuel gauge, idiot lights, temperature gauge, everything.
Get a second independent opinion since this is very unusual. Most likely you have a blown fuse.
Aug 26, 2012 | 1998 Cadillac DeVille
Tranmission and instrument cluster
The speed sensor on your trans sends a signal to the electronics telling it when to shift, this will be where you fault is.
Mar 05, 2012 | 2001 GMC Yukon XL
98 Town Car, how do I change dash lights, (fuel gauge bulb)
  1. Disconnect the negative battery cable.
  2. Remove the instrument cluster.
  3. Remove the retaining screws for the instrument cluster lens and cover assembly. Remove the cover and lens.
  4. Remove the retaining screws for the gauge or warning lamp to be replaced and remove the gauge or warning lamp. To install:
  5. Place the gauge or warning lamp into place and tighten the retaining screws.
  6. Install the instrument cluster lens and cover assembly.
  7. Install the instrument cluster.
  8. Connect the negative battery cable.
Feb 04, 2011 | 1998 Lincoln Town Car
I have a 2005 Envoy, the fuel gauge does not work when full, always reads empty. The stereo only works when it is over 100 degrees and dry outside, the warning sounds (i.e. seatbelt, lights etc) are not...
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Envoy instrument cluster repair
Aug 31, 2010 | 2005 GMC Envoy
Changing dashboard light
Battery voltage.
Door ajar.
Fasten seat belt.
Lift gate ajar.
Low fuel level.
Traction Control.
SELF-DIAGNOSTICS
CodeDescription
Dim test.
Calibration test.
Dim Test
Calibration Test
Aug 09, 2010 | 1998 Plymouth Voyager
Gas gauge no longer works
The light behind myRemove the cluster bezel from the instrument panel. See Cluster Bezel in this group for the procedures.
Remove the four screws that secure the instrument cluster to the instrument panel Instrument Cluster Remove/Install
Pull the instrument cluster rearward to disengage the two self-docking wire harness connectors
NOTE: The instrument cluster has two self-docking wire harness connectors that will be automatically aligned with, and connected to the instrument panel wire harness when the cluster is installed in the instrument panel.
Remove the instrument cluster from the vehicle.
Reverse the removal procedures to install. Tighten the mounting screws to 2.2 N·m (20 in. lbs.)
when I turn my headlights on. All the other gauges are lit, but not the gas gauge. How do I get in there to replace the bulb and fix this? Or is it a fuse problem? I have a 1998 jeep scout Thanks
May 14, 2008 | 2007 Jeep Scout
Computers & Internet Logo
Alun Cox
David Payne
David Payne
