Question about Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub C352 Fuser Unit replacement: How do I remove the fuser unit? After taking out the two screws, it seems to want to slide out easily on the left side, but the right side is obviously connected to something. I do not see anything to unplug / disconnect on the right side, but if I pull any harder I fear I'll damage it. I am replacing the entire unit due to cracks and broken pcs on several joints from heat which is causing jams and error messages.
  • Konica Minolta Master
  • 6,696 Answers
Open the front cover. to your right you will see a small cover with one screw. unscrew and remove the cover. disconnect the three connectors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 11, 2017
Bubbabear64
  • 2794 Answers
SOURCE: konica minolta bizhub C252 printer Problem
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
smt24
  • 54 Answers
SOURCE: put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
Posted on Jun 03, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
mishrajk21
  • 202 Answers
SOURCE: paper jammed at this time error message show on
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Posted on Jul 14, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: can you reset fuser counter without replacing the
You can. You have to remove the fuser, and replace the counter reset fuse that is soldered into the wiring harness, then re-install the fuser. 10 minute job but not a one I would recommend unless you know the machine pretty well. Depending on your location and service options I would try to find a local independant repair person who can do this for you. I reset 20 to 30 of these fusers per year. Note you can also reset your transfer belt unit as well as your Imaging Units as well.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Jan 06, 2011
Testimonial: "thank you very much. I can tell, you're really an expert. your response was very helpful, i will contact a good technician right away to change fuse."
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c352 error 3451
What is error code C3102 in Konica Minolta bizhub 552 printers
Fusing roller failure to turn remove the fuser unit check orange rollers bad replace the fuser unit
May 09, 2015 | Konica Minolta Office Equipment & Supplies
How do I replace the fusing unit in Konica Minolta bizhub C253
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Apr 11, 2015 | Konica Minolta Office Equipment & Supplies
Can you reset fuser counter without replacing the fuser on a C352 bizhub?
WheatlandServices
Jan 06, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Put in newer fuser unit but machine still says to replace
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 161f remove fuser
Usually a fuser unit isn't a replaceable item by the end user. It requires a service technician to repair because they are wired to a circuit board and there are glass components in them that have to be handled carefully.
Jul 03, 2008 | Konica Minolta bizhub 161f All-In-One...
311 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
