Question about Whirlpool Washing Machines
I have a Sears Kenmore commercial washer (coin-operated) with model number 110.20172001. Recently, when we start the wash cycle, it does not advance cycle, but keeps in the wash cycle for ever. Can comeone help me fix this problem ?
Washer_tech
  • 164 Answers
SOURCE: repair the maytag commercial washer with out coins selector
your bearings are going bad. you need to replace the bearing on the top of the brake packag and might have to replace the tub bearing also
Posted on Dec 18, 2007
SOURCE: Coin operated washer
How do you change the price you want your your tenants to pay for washing and drying. It is too high in price? I need to set it to $1.00?
Posted on May 19, 2008
  • 172 Answers
SOURCE: i have a sears kenmore
If the entire agitator is not moving you will have to replace it. If the top is not working properly, you will need the 4 little gears inside the top calle d agitator dogs. The set of four cost about $8.00 and are available at any appliance parts store. To get to the agitator dogs you will remove your fabric softner dispenceer, if you have one. Then pop off the top lid of the agitator. It will have a small spot to insert a screwdriver and pop it off. Then reach down inside the agitator and pull out the next little cover. Be carefull not to loose the seal. Then you will need to unscrew the bolt that you see in the bottom. Once you have done that the agitator will lift off. The top will not pop off the bottom and you will be able to see the four little tear shaped gears called DOGS. I love the name. You should be able to install the new ones fairly easily and then just line the top of tha agitator up with the bottom and push it back down into place. If you look down inside the agitator you will see two little clips that you will need to line up. It is really an easy repair. Let me know if you have any other questions.I hope this will FixYa. Please rate me when you can. Mike
Posted on Sep 24, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
SOURCE: Kenmore Commercial washer 110.20172001
Sounds like motor is bad. See if you can find the 2 main wire leads on the motor and hook up directly to see if you can get it to work.
Posted on Mar 05, 2009
Coin operated dryer
replace the belt.
Feb 02, 2014 | Washing Machines
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Operator and parts manual for a Sears Kenmore washer 400 series
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The model number usually starts with 110.########
To the right of the sub-components list is usually a section where you can see and download PDF operating manuals.
If this is a basic Whirlpool / Kenmore top load, direct drive washer, following are two Whirlpool PDF locations.
The first is the installation and operations manual and the second is a parts list for their top load direct drive commercial washers, (consumer models use the same part numbers).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 10, 2009 | Kenmore Washing Machines
Bottom part of agitator does not work, i replaced the clutch dogs two weeks ago for the top part. kenmore series 80
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
There are a number of Series 80 design washers. You'll need the actual model number to better check for the problem.
First, I'd remove the top agitator (as you've already done), then I'd remove the main agitator.
Under it you will see a clip and what Whirlpool calls a "washer". The "washer has two prongs, one fits into the main agitator shaft drive and the other fits in the lower agitator. If one or the other of the prongs is broken, the agitator most likely wont. I'd also look inside the main agitator to see if the ridges are broken off.
I'd then start the washer on it's smallest cycle and see if the main agitator shaft turns back and forth. If it doesn't and the washer goes through it's drain and spin cycles, the problem is likely in the transmission itself with what they call the agitate gear and / or agitate cams.
Please see the Whirlpool / Kenmore PDF document on installation, maintenance and operation of direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
This is a Whirlpool document with parts lists for their commercial washers (basically the same as the consumer models)
If the problem is in the transmission, although it looks complicated, it really isn't that bad if you have a moderate level of mechanical ability.
Sep 26, 2009 | Kenmore 22422 Top Load Washer
Kenmore 20172 Washer does nothing when coins drop
Sounds like the lever for the coin box needs an adjusment. It may not be far enough back to engage the lever to start it.
May 07, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
157 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
