Question about Kodak Easyshare M753 Digital Camera
I used the wrong power charger on my camera and now it won't work. It doesn't turn on and when i try to charge it with the correct power charger it gets really hot.
jackboy
  • 2985 Answers
SOURCE: Camera won't charge
The camera manual will tell the battery type. If you do not have the manual then the makers web site customer support is the place to go. The same applies to the charger - if it does not supply enough current then the battery will never be fully charges.
Posted on Jul 24, 2007
SOURCE: Cannot charge or get power into my camera
if it does not charge then the camera is useless, and your prolly going to have to get another one. and also it can hyrt the camera if you leave it a long time without charging it.
Posted on May 21, 2008
Agent Allan
  • 480 Answers
SOURCE: mustek camera
Hey mari5,
You have most likely damaged the camera battery and it needs to be replaced. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 22, 2008
marked
  • 6487 Answers
SOURCE: can I charge my v1003 camera in Germany?
Yes that is correct you can use a plug adapter to charge it,,,
Posted on Aug 07, 2009
  • 11967 Answers
SOURCE: lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Posted on Feb 19, 2010
My Fujifilm Finespix S4200 won't turn on
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
If nothing helps, perhaps you should try a new set of batteries and or another charger.
To rule out the camera is defect, put in new alkaline batteries. If the camera starts up normal, you can remove them end concentrate on the batteries and charger.
May 10, 2014 | Cameras
Used wrong battery charger
Charge the battery with the correct charger.
If the camera does not work after charging then the camera is faulty.
It maybe cheaper to get a new camera than repairing the Sony Cyber.
Apr 17, 2013 | Sony Cyber-Shot DSC-P150 Digital Camera
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
Camera never used and won't turn on, battery fully charged.Ideas? Thanks, Deb
The fe-280 user manual notes hat it is possible to insert the battery "the wrong way round" in either the charger, or camera itself (whereupon its hard to extract).
An extract from the faq about it .....
The camera no longer powers on. What could be wrong?
The battery may be dead or underpowered.
If the battery is completely drained, the camera will not power on when the Power button is pressed. If the battery is nearly drained, the camera may briefly display a Battery Empty error message and then power off, or it may power on and then quickly power off without displaying the error. In either case, charge the battery using the LI-40C battery charger bundled with the camera.
Be sure to properly align the arrow on the bundled battery with the arrow on the bundled battery charger. It is possible to force the battery into the charger so that the arrows are not aligned. This is an improper orientation, and the battery will not be charged. For instructions on how to properly inset the battery into the charger, please see "How do I charge the lithium-ion battery?"
So in a nutshell, the first few steps to check are:
1) Are you sure the battery is charged correctly?
2) Have you inserted it into the camera body correctly?
3) Do you have a spare charged battery to check the camera with? (A photo store will do this for you sometimes, if you ask nicely).
Feb 25, 2010 | Olympus FE-280 Digital Camera
Kodak M863 battery only last 2 days.
There is only one battery that is compatible with the camera. 1. You can also try to charge this camera using the computer. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair/Trade up or replace the cable please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 04, 2009 | Kodak EasyShare M863 Digital Camera
JVC Camcorder - used wrong power lead to charge battery
They sell external battery chargers for these for around 10 bucks at Amazon. Just pop the battery in the charger. Beware the battery itself can be worn down or dead. It also has protection circuits right inside the battery that can be blown (maybe a small fuse too). A new high capacity battery (3 times the recording time) is also at Amazon for around $25.
Mar 31, 2017 | JVC Everio GZ-MG130 Camcorder
Kodak Easyshare M753 Digital Camera Logo
64 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
