Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 43" Rearpro, takes a while for picture to come up?? Can you please help??
Hi there
I have a Toshiba 43" rear pro tv, and it seems now to take a while for the picture to come on. Sometimes it will turn on quick and other times it will take ages, I can hear that the tubes are still going just no picture or blue screen of any sort. Once it comes on its usually sweet as, sometimes will flicker or roll a bit. Any suggestions as to what it could be is much appreciated.
Cheers
Russ
  • 4 more comments
  • Rusteee Apr 26, 2008
    Hi again.
    Awsome thanks for that, sorry to sound a bit dumb lol but where is the vertical output ic? Now I have just tried the tv and no picture comes on, only sound, although the tubes are still working. Is there a video board fault or sometihng of the sort? Do you have a service manual for this? its a Toshiba 43vh9ua.
    Thanks again for any help
    Cheers
    Russ
    Mate, you are brillaint! I'm just going to sign up now, this site looks awsome!
    Cheers, I'll keep you posted
    Awsome, I've signed up and paid for the manual. How long does it usually take before it will come through?
    Yep, hope this is the e-mail now. I hope it is just the ic's, I can here the tubes start up, and then when left on and then turn off all the static discharge or whatever it is doing, and when the pic does come on it comes on instantly so the tubes must have been already going. I can't seem to get any picture out of it now, I did before but then it just went all funny and has gone again.
  • Rusteee Apr 27, 2008
    Awsome, seems the online technician has gone off lol, are the vertical IC's the 2 main ones located at the back of the board attatched to the 2 big heat sinks?
  • Rusteee May 03, 2008
    Dammit, after fitting new IC I get no picture at all not even after waiting, but the green tube only just lights with a whole heap of lines that go across and half way down start bending towards the bottom of the screen,,,,?????? Any ideas
  • Toshiba Master
  • 8,617 Answers
Try resoldering the vertical output ic, see if that helps.
Posted on Apr 26, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Apr 26, 2008
    its usually the vertical output ic that needs resoldering or replacement when the tubes light but no picture. The other site where I work as a support tech does have your service manual for sale which they email you right after purchase, and they then provide you with fre unlimited yech support by on line instant nessageing to help you repair your set even locate any part that you need. heres the link, I put your n=manual on the front page in case you'd like it its easier to find that way. heres the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    you will like that site we have over 300 customers that we have helped repair their sets in the past 30 days.
  • Sonny Berry
    you should get it within minutes as well as the support account invitation they are fairly quick.
  • Sonny Berry
    definately sounds like the vertical IC as thats what happens they blank out to protect the tubes when the vertical drops out then its instantly on when the vertical comes back up.
Hi , i have toshiba 43" rear projection tv, the picture is not stable and bouncing all the time and the colors are oufull mainly blue red and green, what can it be ? are the lamps are finished ? the...
I would like to view that short video clip to diagnose possible cause of picture problem and would you please confirm model number of tv that would be written at rear?
Thanks.
Apr 29, 2011 | Toshiba 43A10 43" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
TV Picture
try unpluging the power and pluging it back in.
Dec 11, 2007 | Toshiba 43A10 43" Rear Projection...
Picture blurry
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
try doing a magic focus
Dec 10, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba TN43V71 43 in rear projection
Hello WendyOreo,
It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out.
I say this because there are voltages in a TV set that can kill, so caution is needed.
I hope this helps
Thank you,
Shuttle83
Oct 17, 2007 | Toshiba TN43V71 43" Rear Projection...
Blue ghost
If you have the ability to work on solid state electronics and know how these circuits work, you will need to replace the convergence IC's in this TV set. If you do not, call in a pro to assist you in this repair. Good Luck
Jun 20, 2007 | Toshiba 43H71 43" Rear Projection...
Wavy lines
This TV uses small voltage regulators. On each side of the regulators is the input voltage and the regulated output voltage on the other side. There are capacitors used for stabilization on the input and output. Change these capacitors.
Oct 25, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
