Question about Kenwood KDC-MP435U CD Player
I got a Kenwood KDC--MP245 & I've got a regular amp I want to hook up. Where do I put the power supply wire to the kenwood wires? Joseph
P. Cont wire that us usually blue and white
Posted on Dec 16, 2010
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I have kenwood mp245 and the protect word is displayed what can I do to get the radio to play
Make certain all speakers are good the cables are not damaged and there are no bad connections causing a short.
If that doesn't clear it you may have a shorted part, such as a transistor in the amp section.
Jun 30, 2012 | Kenwood KDC-MP245 - CD/MP3 Receiver
New kenwood kdc-mp242 installed turns on but no sound
The Blue/White wire, Brown wire, and Blue wire???? These don't have to be connected unless you are using a separate Power Amp...if you are, then the Blue/White wire needs to be used to switch on the power amp. Here is a link to Kenwood for your KDC-MP242 Instruction Manual. Reference page 16.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/kdcmp242.pdf
Dec 28, 2009 | Kenwood KDC-MP242
What is the dark blue wire comming from my kenwood kdc-516s deck?
It is probably the remote amp wire or power antenna wire. you can check by hooking up a volt meter set on 12 volts DC and see if there is power when you turn on the unit
Oct 03, 2009 | Kenwood KDC-516S CD Player
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
Kenwood KDC-138: Removed Old stereo, installed new KDC-138, I'm getting power to the plug that plugs into the back of the unit & fuse is good. I've tried pushing the reset button. Nothing comes up on...
do you have power at both supplys on the wire harness?( red and yellow) red wire will have power with the key on. Also make sure your ground is hooked up right.
Aug 02, 2009 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Kenwood kdc-1028
the remote is blue - the ignition wire12 volt is red - the battery line 12 volt is yellow
Mar 26, 2008 | Kenwood KDC-1028 CD Player
Kenwood KDC-MP435U CD Player Logo
329 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
