Question about Whirlpool GEW9250 Electric Dryer
Dryer isn't heating up. - Whirlpool GEW9250 Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryerDryer isn't heating up. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 06, 2010
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
My dryer isn't drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 22, 2011 | KitchenAid Dryers
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
heatman101;
Jul 22, 2011 | Dryers
I have an he3 dryer that isn't heating. is there a reset button on the dryer?
heatman101;
Jul 22, 2011 | Kenmore Dryers
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
The drying light is flashing and the dryer isn't heating up
heatman101[]\==-
Jun 26, 2011 | LG DLE2514 Electric Dryer
Cabrio Electric Dryer isn't heating up
heatman101
May 29, 2011 | Whirlpool WED6200S Electric Dryer
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
Whirlpool GEW9250 Electric Dryer Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
