Question about Dell Dimension 4700 PC Desktop
What do I need to be set up for wifi? I ahve windows XP. I've never had wifi, we have a cable modem.
    Brigadier General:
  • 4,044 Answers
A wireless card or device for the computer and a wireless router. You maybe able to connect, and most likely will, a second router to the cable modem to take your signal wireless. The computer will need a card or USB device connected to it so it can use the WiFi network your going to create. Once you have the device and router in place follow the Setup directions for creating a home network in Windows. There is actually a wizard in the network center to assist you with this in windows.
Posted on Aug 05, 2010
My laptop is HP. With windows 8 I need to turn off broadband ?? To connect WiFi lan setting only..No dial up
If your HP has a Wireless adapter - should have - you should connect to WiFi as soon as you start up your computer. Some start up WiFi throgu a compination of function keys, you should check your keyboard and your user's manual.
I don'r Understand what do you mean by "connect WiFi Lan settingg". WiFi is not the same as LAN. LAN is the cdirect conection to a broadband modem and if your LAN port is coonected through a cable to your modem, you connect to Interent at startup,
No dial up? I'm not sure if anywhere in civilized wold anyone with a computer still uses a dial up Internet modem.
Resumed: EXCUSE ME BUT YOUR QUESTION IS A MESs
May 26, 2015 | Computers & Internet
FORGET THE PASSWORD
it should be written underneath the modem
Apr 07, 2014 | D-Link Wireless N Access Point Dap-1360 -...
My dad gave my son an elderly (2001) HP Pavilion xf145 notebook with windows xp. We can't figure out if we need to add a wifi card of some sort, if it can even connect to our wifi or what. It seems to...
You can use either external wifi modem and connect it to the notebook by ethernet cable or (better) use PCMCIA wifi card (second-hand e.g. from eBay?) or wifi usb modem connected direct to usb port. Just check if choosen wifi modem supports your OS WIN XP (and service pack - e.g. WIN XP SP3). In the Reference guide of the notebook is not specified USB version - it seems to be v. 1.0, so it is necessary to get an USB wifi modem compatible with USB 1.0 standard.
Nov 11, 2013 | HP Pavilion xf145 (F3413HR) PC Notebook
NV55C Gateway Lap Top cannot connect to wireless router
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Jan 23, 2012 | Gateway NV55C03u Laptop
Connect to wifi on blackberry and ps3
It is just be a matter of synching the blue tooth system of the blackberry to that of the PS3. Assuming the PS3 is not currently connected to the web or connected to a modem, you should be able to search for the PS3 by using the Bluetooth search tool in the Blackberry setup menus. Then for headsets,set those up through the PS3 by turning on the head sets, and then using the Blue tooth set up utility of the PS3 to search for the head sets.
Otherwise If you do not have Wifi active currently and don't have good cellular coverage in your area, you can use a Wifi Bridge Dongle (connector cable) like this one, there are others available too.
http://www.espow.com/wholesale-wifi-bridge-dongle-wireless-for-dreambox-xbox-ps3.html
to connect the PS3 to your home computer and use it as the hub assuming you ahve it connected to DSL or broadband. headsets would set up the same way.
Jan 04, 2012 | Sony Playstation 3 (PS3) Console
I was just given an older laptop that does not have internal wifi so it came with a wireless adapter. I've never used one so I have no idea where to begin. There is no brand name or model name on it....
you prolly need to load the drivers for the adapter......if its possible that you can connect the laptop to the modem/router with Ethernet cable, then insert the card and run windows updates and see if windows finds a driver for it......once it does and installs....then the wireless card "should" see the wireless signal off of your router
Aug 06, 2011 | Computers & Internet
Need to set up wifi security
Find your modem on this page: http://www.pcwintech.com/screenshots-actiontec-routersmodems
..once you've found your modem you can type "192.168.1.1" into your internet browser. There will be an option for wireless once you're in there.
Apr 29, 2011 | Actiontec (GT701) Modem
How i can setup Wifi to Thomson (DCM305R) modem?
Hello, Thanks for the opportunity to help you.
First off you modem there is not wifi but cant be hooked up to a wifi router that you can purchase from any computer store.
The modem would hook up to the router directly instead of hooking to the computer via RJ45 "ethernet cable"
The wifi router would then share that connection. You would need to set that up with some security I recommend WPA 2 encryption you will need to select a password/ or pass phrase.
In order for me to give you the How To's we would need some more information such as:
1. Brand name of router
2. Model number
Click here for some basic information on how to hook up a cable modem to a wifi router.
Thanks for using Fixya.com , We hope your found this Very Helpful.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 25, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
Cannot connect to wifi on our bt home hub
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
Dell Dimension 4700 PC Desktop Logo
381 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
