SOURCE: ho do you remove the dr power window motor , do you have to remove the regulator?
You will have to pull the door Glass out with the window regulator to change the motor, I have done this repair many times, it's a pain
SOURCE: Which rivits need to be removed to take out the RH window motor?
The revits can be drilled out and the new motor should come with small bolts and nuts to replace the revits. However some people choose to put back rivets which s fine as long as you have a good rivet gun.
SOURCE: trying to add drives to an HP Elite desktop computer.
you can download the user manual from site listed below, will show you how to install HD and open case.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=135&prodTypeId=12454&prodSeriesId=430118
SOURCE: Have a HP Elite 9500
The side with the thumb screws is your side panel that allows access to the inside of your computer. On some computers only one side comes off. Hope this helps...
