SOURCE: EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
SOURCE: I need driver Epson TM-T88IV for linux Suse 11
go to this site to get detailed information:
http://www.epsondevelopers.com
wrote a tip http://www.fixya.com/support/r672100-epson_impact_printers_mac (mac's are unix)
SOURCE: tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
SOURCE: What is the IP Address for Epson TM- U220PD
The best way to connect to this printer is to plug the network cable from the printer into a PC, set your PC to Static IP 192.168.192.100 Subnet 255.255.255.0
Save your settings, and than open internet explorer, or firefox, and access the printer by going to 192.168.192.168
This will allow you to change the settings to your current subnet, and save.
Hope this helps.
Sincerely,
Ryan Deschaine
Systems Engineer
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: [email protected]
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
