Hi! I'm trying to charge my camera, and when I conect the charger the charging light is green and inmediately change to red, lighting 3 times in red and then it turn off. I can notice that it is not getting full charge and is the first time it happens
The red and green lights indicate if the batteries in the charger are either charging or are finished charging.
If they are charging, the light will be red, and if they are finished charging, the light will be green.
Thank you for choosing FixYa!
Usually when the light on the charger either changes from red to green, or some chargers have a blinking light, when it stops blinking. I have seen chargers which also had a light which would turn off when the battery is charged.
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
