Question about Lexmark X7350 InkJet Printer
Got a fax, was out of ink, said it saved it to memory to print later... where do I ascess the memory now that I have new ink to print the fax?
    President:
  • 2,571 Answers
Check your documents folder, or the lexmark program files folder
Posted on Aug 05, 2010
How to print faxes from the lexmark x5630 which is stored in the memory
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
The memory is full and my fax keeps reading no ink. I replaced the cartridge twice and it still reads no ink. It is a UX B-20
Don't worry about the memory being full, the problem is the ink, and once the machine is able to print the FAX will empty memory by printing the faxes out. This might sound bad but I have seen this happen, when you unpacked the new ink cartridge, did you pull off the little plastic protector? And is the paper loaded?
Dec 03, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
Canon PIXMA MX330 multifunction printer. I get a lot of faxes. Is there a way to save ink & paper by having all faxes come in without printing them & just putting them to memory & review them...
unfortunatly not!The m/c will print each and every fax!I can suggest getting a fax to email nr and recieve the faxes on your pc and then printing what u need!Memory does keep about 258 pages depending on the coverage on the pages!
Feb 22, 2010 | Canon PIXMA MX330 Multifunction InkJet...
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Can I reprint a fax that I just received?
If you want to reprint a fax because the print cartridge was empty or if the fax was printed on the wrong type of media, you can try to reprint it. The amount of memory that is available determines the actual number of faxes that are stored for reprinting. ... These faxes are stored continuously.
here's how if you have this accessibility..
Press "Setup" on the control panel of your fax machine. Most fax machines will have an LED display panel on the front of the machine. The panel will usually include on screen prompts and help options. Some fax machines signal the user if they have faxes stored in memory and prompt the user to "print faxes" or "clear memory," but you need to make sure that you don't accidentally clear the memory or you will lose all saved faxes.
Use the arrow keys or number pad as directed by screen prompts to select "Fax Setup Menu" and then press the "OK" or "Start" key.
Enter the security code, PIN, or user authorization code if required. The security code or PIN protects sensitive information and prevents unauthorized use of the fax machine memory. If you haven't set it up you don't have it.
Navigate to "Receive" or "Print Faxes in Memory" and then press the "OK" or "Start" key as directed by the on-screen prompt. The last fax stored in the machine's memory should begin to print.
Repeat the above steps for each fax in memory if you need a different one.
Hope this helps and isn't clear as mud!
Happy new year.
problem? make and model # please.
Jan 01, 2018 | HP Officejet 4110 All-In-One InkJet...
Fax
From the manual:
If ink has run out while receiving a fax, if the paper size setting is incorrect, or if the paper type is set to a type other than plain paper, the fax is automatically stored in memory and <Received in memory.> is displayed. When the ink tank is replaced or the paper size/type setting is corrected, the stored fax is printed automatically.
Also, if the machine is in the process of something else (printing from computer, making a copy, scanning to computer), when a fax comes in it will be saved to memory, but it should print within a few minutes of becoming idle again.
May 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Reprint last fax
JUST OPEN THE TOP COVER PUT IN NEW INK CAARTRIGE THEN FAX WILL RESUME PRINTING FOM MEMORY AS LONG THE POWERS WASNT TURNED OFF
Dec 31, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Lexmark X7350 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
