Question about Watches
The clasp on my wife's wittnanuer watch just split in two, where can i get service on this or is it covered by the company & how can i rach them ?
  • 2,334 Answers
Follow this link:
http://www.bulova.com/service/servicecenter.aspx
Go to the very bottom. There you will find WITTNAUER which is made by BULOVA.
Posted on Aug 05, 2010
Skagen watch - 233 SGS - the clasp on the stainless steel bracelet is not secure - the clasp comes undone in normal use - nothing energetic - and the watch falls off - been lucky so far as have either...
Hi ,
i would contact Fossil group as they are the manuafcturer of Skagen watches . looking at the model it uses a slider type clasp.
the metal on the locaking part can be easily bent causing to come undone.
Aug 25, 2017 | Skagen Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
I need a clasp extender for Anne Klein watch. 10/8213. This is a bronze colored watch.
Most watch companies will give out extra links with a purchase. I would ask the retailer you bought from first, and if no luck there, I would try AK direct at this link:
http://www.anneklein.com/Customer-Service/HELP,default,pg.html
Aug 18, 2010 | Watches
Replacement clasp for Anne Klein watch, caseback #12/6130-1
mcdevito75 here, Your in a spot with your Ann Klien watch. BEST BET, shop ebay and match up another Ann Klien just like yours and use for parts. On ebay Click in search, watches then Ann Klien.
Jul 26, 2010 | Anne Klein 10 7977MPTT
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
My wifes cartier santos Demoiselle requires new clasp the original is bent and wont lock. can you recommend company that wont cost the earth
You might be able to put a generic clasp on it! Check around for a local reputable watch repair shop in your area!
Jan 14, 2010 | Cartier Watches
How to remove links from band
This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
Sep 22, 2009 | Festina 16177-4 watch Watch for Men
I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
Sep 19, 2009 | Watches
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Jun 17, 2008 | Watches
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
