Question about Acer AL2216W LCD Monitor
Why do I have to re-start my Acer AL2216w monitor several times before it will stay on?
  • 1,684 Answers
Slow starting, no power or a flickering display are all indications of a failing power supply. Check out this article on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/ The power supply board in your monitor should be the DAC-19M010. To correct the problem you will need to replace the capacitors that are failing. You will need to replace 7 capacitors on the board. This does involve a bit of soldering but is an easy thing to do. If you don't want to do the repair yourself we do offer a repair service, you can get the details of that here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Aug 21, 2010
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
I Have an ACER AL2216W LCD Monitor. Problem Screen comes on than seconds later cuts off. I get the green LED than it goes back to yellow or some times stays green but goes black screen
Does it do the same whan attached to another PC? Cables are good?
If it is monitor, you will need to check the caps and DC voltages first.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2216W/
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Mar 14, 2011 | Acer AL2216W LCD Monitor
Not Good..
Jan 30, 2011 | Acer AL2216W LCD Monitor
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
Monitor turns on flickers twice then stays at a black screen
Test that your memory chips are fully inseted in their sockets as this can some times prevent displays from working.
Sep 07, 2010 | Acer AL2216W LCD Monitor
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER AL2216W.
remove the hinge cover, then remove the six screws you see there. Then the base slides out.
Feb 10, 2009 | Acer AL2216W LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Acer AL2216W LCD Monitor Logo
995 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
