I tpe my ip number but my router adminstration page wont come up
    Scholar:
  • 61 Answers
What make of router do you have? Are you connecting to the router with a LAN cable in the first instance - you will need to do this to configure the setup first before you go wireless
Posted on Aug 05, 2010
Want to connect my c2020 to a new network
First decide whether your going to use the LAN hard wired or wi_fi wireless. Then locate the ip-adress of the new network the name of the domain. or ssid of the new modem or net work example:att who ever is in charge of the adminstration rights to the new network. plug the machine into the router if its dhcp the router will take from there. on the machine go into additional functions<network settings<ip address. with the ip address of the new network you will clear the old and replace the new,example192.168.1.1. if you have a smart phone it will help you find these necessary numbers to plug in. or go to browser and type in http://192.168.1.254 this will get you to the router or modem. it will display a data page with a lot of numbers. you will need its password and its on the modem/router back or bottom. then look for devices on the network you should see the machine look at the ip the router/modem gave it. write it down match the machine with same number and hit print 192.168.1.254 will let you send test page. or call a IT man.
Mar 04, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Belkin Wireless router
Is the laptop connected to the router wirelessly? because that can be the porblem if that laptop is not connected wirelessly it wont be working, so make sure that the laptop is connected to your wireless network...
Hope that helps..............
Sep 03, 2008 | Arris Wireless G Broadband Router (wr850g)
INTERNET PASSWORD I THINK THE NUMBER LOOK SOMETHING LIKE THIS 183.183.181.192 I THINK BUT IM LOST AND REALY NEED HELP FOR MY MODEM
Connect to the router with a cable and access the router adminstration by the Router IP address. If this was setup by a service provider only they will know the User name and password used to access the router directly. If it is out of the box the IP is most likely 192.168.0.254 with admin and the user and administrator as the password exactly as you see them in this post. You can see the Wireless security key under wireless Security settings in this router.
Jan 17, 2011 | Linksys WRT160N Wireless Router
How to change default gateway
Default gateway is the IP address of the router.
Connect the computer to the router.
Open the setup page of the router using the current default gateway number.
On the setup page of tghe router, you will see the router local IP address.
You will find the current IP address of the router there.
If you want to change the default gateway, you can change the router Local IP address.
Make sure that it will be a private IP address only and not the public IP address.
suppose the current default gateway is 192.168.1.1.
You can change it to 192.168.x.y. X and Y will be the number between 0 to 254.
Click Here for more information about the routers and network
Jul 03, 2010 | NetGear DG834G Router
BROADBAND SLOW NEED TO GET TO ROUTER LOG IN PAGE
to get to the router's login page its almost always the same ip address as your pc minus the last number .. so go to start then run. Type CMD hit enter. Then type ipconfig and note your ip address should be something like 192.168.1.x your router will be the lowest number in the last number . so if your ip address from the step above is 192.168.1.101 your router is probably 192.168.1.100 or 192.168.1.1. Then you would need to google "default admin password router model" where you insert your model number of your router. Then login and tweek the settings you like to make your connection faster. hope that helps.
Jun 27, 2010 | NetGear Computers & Internet
Can not access router setup page. IP is to be 192.168.1.102 , says can not find. This is the main computer on network, other's are wireless.
The number 192.168.1.102 must be your computer's IP address.If you want to access the router set up then You will need the Ip address of the router.
Is your computer connected to the router with the cable. if not then connect the computer to the router and check the IP address and default gateway on the computer.
Once you have the default gateway number use that number to open the router set up.
Generally the Linksys router IP address is 192.168.1.1.
Try this number.
Apr 22, 2010 | Linksys Wireless-G WRT54G Router
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
I can't connect HP Officejet
If you have adminstrator access to your router, this will be somewhat simple.
First we need to find out what your local ip is on your network. Hit Start > Run > type " cmd " and hit enter. In the new window type ipconfig and hit enter. You will see some information pop in the view. IP Address and Default Gateway are the numbers you will need. Either leave this window open so that you can see it clearly, or write down those 2 numbers and be sure to label them clearly for easy reference.
Now, open your browser, (internet explorer or firefox... etc) in the address bar type in the number for Default Gateway, most likely 192.168.0.1, hit enter.. here u will be asked for a username and password. Hopefulyl you have set this and know it.. if not.. try User: admin(istrator) Password: Password (or admin(istrator)) IF you are able to get in, follow these steps.
Go to Applications and Gaming
Enter the name of the program into the first box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Under "Start" put 426 and under "End" put 428.. this gives a lil leeway, some routers will use the start/end numbers some wont so putting 427 to 427 may not work. Under protocol, select UDP under ip address.. pretty self explanatory.. put the last portion of the 4 segment ip address you got fromthe command line interface in the first step. check the box underneath enable and click save settings.
This will allow whatever programs you need, to access port 427.
Be sure to password protect your network . Not doing so will allow anyone thats devious enough to be looking, to access whateer they want on your computer and network.
I hope all this helps you, please let me know if it does not!
Aug 30, 2009 | Linksys Wireless-G WRT54G Router
Problem reinstalling my linksys wireless router after format
Change your ip address on your computer temporarily to some number in the 192.168.1.X range so that it is on the same subnet as your router.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to Netgear wireless router adminstrator page
Maybe that's not the correct IP address.
If you have Windows XP:
1. Click Start
2. Click Run
3. Type cmd and press enter
4. Type ipconfig and press enter
5. Look for your gateway address, that's the address to put into your address bar.
Vista:
1. Start
2. In "Start Search" type cmd
3. Right click cmd that appears on the top and click run as administrator.
5. Look for gateway address
Jan 12, 2009 | NetGear WGT624 Wireless Router
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
