Question about Whirlpool WTW6400SW Cabrio Washer
I keep getting an F1 code when my washer starts the fill up
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
What is F1 failure code on a kenmoore oasis washer
check your owner manual section troubleshooting for error code very important.
Normally this error code can be meansL a) pressure out of range.
or b)eepron error.
or call the factory and get support online via chat or phone for to fix it.
God bless you
Sep 25, 2012 | Kenmore 4.7 cu. ft. High-Efficiency Top...
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an error code F1. There is NO explanation in the manual just call a technician....what can i do to check things out? the wassher begins to fill up with water then stops abruptly flashing...
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%#
Aug 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive).
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F1 code
have the same the washer show F1 I have to hit pause start 3 time befor it will wash severly people have the same proble with this whirlpool washer it is a tiner proble i hve been tool.
Jan 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
473 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
