Question about Toshiba Satellite L305-S5908 Notebook
Error code oxcoooooe9 what does it mean - Toshiba Satellite L305-S5908 Notebook
    Guru:
  • 1,082 Answers
error code oxcoooooe9 what does it mean - tech_details.gifAn executive worker thread is being terminated without having gone through the worker thread rundown code, which is not allowed.
After the Stop code will be 4 hex values: {Parameter 1, Parameter 2, Parameter 3, Parameter 4}.
Parameter 1 specifies the exiting ETHREAD (the ETHREAD structure is an opaque structure that serves as the thread object for a thread).
Parameter 2 is not defined.
Parameter 3 is not defined.
Parameter 4 is not defined.
Have you recently installed a new device or software? If so, system restore might fix you up. This site will show you how to determine what specific module caused the problem. It is somewhat complex but just follow the instructions.
http://thelazyadmin.com/blogs/thelazyadmin/archive/2006/05/23/Debugging-STOP-Errors-With-WinDBG.aspx
Posted on Aug 05, 2010
Asus laptop oxcoooooe9 error what does this mean can not afford to send to be repaired so anyone with anything that could be helpful as my daughter needs this laptop for school ASAP Tia :)
The usual issue to cause this error code is the hdd is failing or failed. Replace the hdd, install your OS, drivers, programmes and with a usb - hdd adapter, try to recover your data.
Feb 03, 2014 | Computers & Internet
How do i fix error oxcoooooe9 on my sony laptop
That is typically a "memory address error".
Save all "My Documents" to an external hard drive.
Reload Windows.
If the error persists after doing Windows Update. you may have generic memory causing the problem.
go to www.crucial.com for memory upgrades.
Feb 15, 2013 | Acer Aspire T135 PC Desktop
My computor says it has been interrupted it does diagonostic says error 303
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 29, 2012 | HP TouchSmart IQ770 PC Desktop
My daughers toshiba satellite L750 keeps showing status oxcoooooe9 I/o error
sounds like the hard drive is failing and needs to be replaced, however, if you can backup your data, do so and try to run CHKDSK /r and if that does not work, your next move is to reformat and reinstall the operating system
Jun 09, 2012 | Computers & Internet
How I can fix this error(oxcoooooe9)?
Search Results
  1. error
    code on blue screen OxcOOOOOe9 I/O error
    Hello Dozeymare, Status: error
    OxcOOOOOe9
    Info: Windows failed to load because the system registry file is
    missing, or corrupt. Sorry your only recourse would be to reformat
    ...social.answers.microsoft.com/Forums/en-US/vistamedia/...
    - Cached
Jan 31, 2011 | Computers & Internet
Windows boot manager file: /boot/bcd status: oxcoooooe9 info: an unexpected I/o error has occurred I am experiencing the same problem on a Dell laptop (Inspiron 1525: Windows boot manager - file:...
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
May 09, 2009 | Dell Inspiron 1525 Laptop
Toshiba Satellite L305-S5908 Notebook Logo
1,135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
