Question about Troy Bilt 5.5hp Self Propelled Mower
Hi John, my Troy-Bilt self propelled lawn mower has a loose V-belt that I need to replace. It didn't snap but it did slip off and I was able to get it back on the pulley. But now it's too loose. How do I get the new belt on? There doesn't seem to be and easy access to the pulley. I have an authorized Troy-Bilt repair place nearby, they charge $75 per hour. I'd rather do it myself if I can. I read online about the 2005 V-Belt recall problem & wondering if this is part of it. I do have the receipt. Thanks so much. Purchased 2008 Model 12AI869F011 Serial 1A209K30701 Lyle
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
  • 68 Answers
SOURCE: lawn mower
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Posted on Apr 26, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Posted on Jun 05, 2009
SOURCE: Troy Bilt 33
If you didn't by the Troybilt belt, try that. I had the same problem with a Napa belt. Going into drive as soon as I grabbed the operator presence button, not coming out of gear etc. When I switched the the Troybilt belt, the problem went away.
Posted on Aug 16, 2009
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
The mower will not self propell. could it be that the belt is worn out? Or do I have a bigger problem? If so what should I look for? Thanks, John
Hi john, yes your belt could be cracked and not tight enough to run the drive. Also check your cable adjustment to be sure it is right.
May 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Drive wheels dont seem to propel mower
SOME SELF PROPELLED MOWERS HAVE A SHEAR PIN IN THE DRIVE BOX THAT MAY HAVE SHEARED . IF THE MOWER GETS A LOT OF USE THIS PIN CAN SHEAR. ALSO SOME HAVE A FRICTION DISC, LIKE A CLUTCH THAT MAY BE SLIPPING. CHECK THESE TWO THINGS CAN'T TELL MUCH MORE WITHOUT A MAKE AND MODEL
Sep 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Mower Belt Slippage
If you have an tension adjuster on the handle loosen up until you can slip it back on. If thats not enough remove the spring at the tranmission.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i replace a drive belt on a troy bilt self propelled lawn
May 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
149 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
