Question about HP Pavilion tx2110us Tablet PC
2 out of 3 times my tx2110us won't show boot prompt on the bottom of the screen and then hangs up. When it is shown, I tried command line commands, 'bootrec / fixboot' and 'bootrec /fixmbr,' and they were successful. But still the same problem. Hard disc is OK - Comprehensive diagnostic test result's good and I could restore program from the partioned D: drive of the hard disc. Your help will be greatly appreciated.
    Sergeant:
    Champion:
  • 263 Answers
First of all Back Up your all Hard disc data with UBUntu live cd.then fully format Hard disc and then reinstall your OS.your problem will be solved.
Posted on Feb 05, 2011
  • Anonymous Feb 05, 2011
    Try to reinstall your OS
I can't get my trio AXS tablet to get off of No Command and Now send package.
Remove the battery from your phone/tab in order to get it to power off or shut down first.
Next, perform a hard reset on
Press at the same time any of these combinations
Power on + volume up button
Or
Power on + volume down button
Follow the menu prompt to reset your phone/tab
Where no command and the android logo on its back and with its tummy opened is still displayed, attempt to press any of these buttons/keys
Home button alone
Or Volume down button alone
or Volume up button alone
Attempt is to call out the hard reset command prompt
Give these tips/steps several tries.
If all else fails to work, you may have to flash stock ROM firmware of your phone/tab
Oct 14, 2017 | Tablets & eReaders
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
I am stuck on the boot up screen and wont let me reset
Pull battery. or
search for cmd.com
execute cmd.com
type in " shutdown /s " to shutdown the computer at command prompt
type in " shutdown /r " to reboot the computer at command prompt
Jan 21, 2014 | Proscan Recertified - PLT8031 4GB NAND...
Delll latitude xt wont restore to an earlier restore point
Hi kaliyahsherr,
I see that your Dell will not restore to an earlier restore point.
What version of windows do you have on your Dell?
I believe you already did try to do system restore but it did not work right, does it give you an error unable to restore to the selcted restore point, if that is the error then meaning there is a peroblem with that restoration point that you have selcted have you tried a different restore point?
If you did then most probably the system restore program on your windows is having issue restoring the system to any date that you may have on your system restore. if this is the case then the only option would be reinstalling windows starting from scratch.
There is another way to do System Restore on your computer but this is only known to work with Windows XP, I haven't tried with Vista nor Win7 yet.
we do a System Restore in the Command Prompt, see steps below.
> From shut down turn your Computer back on then keep on tapping F8 to select and boot into Safemode in Command Prompt.
> Once in the Command Prompt on the blinking cursor you should type in \windows\system32\restore\rstrui.exe after typing this in it should look like this C:\windows\system32\restore\rstrui.exe, then press Enter.
> After pressing Enter this should show you a list of dates for the restore points highlight a data and time when you want to do the system restore and see if it will work outside windows.
> If this does not work then there is something wrong with Windows and needs to be reinstalled for the fix on your concern.
I hope that this information can be helpful regarding your concern.
Have a nice day,
mvincentc
Apr 30, 2011 | Dell Latitude XT Laptop Computer Tablet...
How to format c drive for a Acer travelmate c110 from command prompt
You can't format a computer from the command prompt. the only way to format a hard drive is to get the disk for the operating system. put the disk in the computer then restart the computer. when the computer is starting up at the bottom of the screen will be some commands, one of the commands will to boot from disk. select this option. they the computer will take you through a bunch of screens asking whether or not you want to do this because formatting your hard drive will erase everything on your computer. once you say yes to all these screens you computer will start formatting.
I hope this information was helpful, if you have any comments or questions reply to this post and i will help as much as possible
Nov 10, 2010 | Acer TravelMate C110 Tablet PC
Acer travelmate c110 blue screen , how to fix it
If windows won't boot and if you have tried the safe mode and "Last Known Good Configuration" mode, then try the procedure below and repair the windows installation files.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Jan 15, 2010 | Acer TravelMate C110 Tablet PC
I have a HP Pavilion tx2110us tablet notebook, running Windows Vista Home (32 bit). It will no longer boot up. At times when I pressed the 'esc' button intermittently it would boot up "by chance". I have...
I got this Hp TX2110us when it came up which i hardly use (bought at Fry's). But one time while using it Before Christmas, it jusy shuts down completely. I tried removing the battery and jusy use the AC adapter (has voltage) but no light at all anywhere. The power slide switch won't do a thing. Please anyone know aboutthis??
Jan 10, 2010 | HP Pavilion tx2110us Tablet PC
My hp tc 1100 will boot up it goes into scandisk hen before it starts it reboots again and it keeps on going
try pressing F8 then safe mode with command prompt after that when the windows is open type chkdsk on the command prompt. then after its finished scanning press quit, if it has an error type chkdsk/f to fix the problem.
Jan 04, 2010 | Compaq tc1100 Tablet PC
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
Panasonic CF-18
The command.com is a key file in the booting up process of computers. You either have a virus that destroyed it, or your hard disk drive is failing. Try going into the CMOS and make sure the CD is listed in the boot order and first, then boot to system CD.
Oct 17, 2017 | Panasonic Toughbook 18 Convertible Tablet...
HP Pavilion tx2110us Tablet PC Logo
236 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Marvin
Marvin
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
