Question about Heritage Dryers
Hi im trying to install a fan, i have 4 wires total... ground black white, i know where those go, but there is a blue wire labeled light kit connection... where does that go??
    Genius:
  • 1,970 Answers
Mcdevito75 here, I would imageine to the lights that came with the fan. If your laeveing the lights off the fan, just tape over the blue wire so it doesn"t short.
Posted on Aug 05, 2010
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Dec 22, 2016 | Dryers
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
On emerson casablanca ceiling fan, there is no voltage between blue and white wires for lighting kit power.
Check blue wire to bare ground.
Then check each wire to bare ground, with switch on and off.
Add a comment with result.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 16, 2012 | Dryers
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Am installing a ceiling fan and do not have the installation instructions. The fan has a black wire (labeled Motor), a white wire (labeled Neutral) and a blue wire (labeled Light). What is the proper...
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
Aug 04, 2010 | Heating & Cooling
Light kit
Hi .. usually the light kits come with only two wires that are not connected .. a white and a black. Look again in the install kit and make sure you have located all the wires .. the wire you want is connected to all the lamp sockets .
May 03, 2010 | Casablanca Fan (3845T) Brushed Nickel...
When wiring up the light, blue wire for the light should connect to the black wire in electrical box, correct
connect white wire from light kit to white wire labeled "for light" then connect black wires from light kit filter to blue wire from fan. Use wire nuts to make the connections
Feb 06, 2010 | Hampton Bay 24002 Ceiling Fan
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
Top Heritage Dryers Experts
roeb
Michael Galve
Michael Galve
Mike
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
