Question about PSC MAGELLAN 9500 (202020211120103a) Fixed Mount
I am looking for error codes for magellan 9500
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
Aug 17, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
How to unlock a blackberry storm 9500
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Storm 9500 Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.i hope this will help you :)Good Luck.
May 20, 2010 | RIM Research In Motion Blackberry Storm...
Error code 57.70 on HP 9500 color printer
What is the code? This unit does not have a fan in the duplexer nor for the duplexer. The 9500 has a fan housing but there was never a fan put in by the design team. Give the code and I look it up to see the problem.
Apr 28, 2010 | HP LaserJet 9500n Printer
Vertical laser error
If the error code means "vertical laser error" you could check for the flat connector of the vertical laser module. Here I send to you an image to explain it. 0b500ff.jpgIF all is ok. you could try with another vertical laser board and replace it
Apr 20, 2010 | Datalogic Magellan 8500 Wired Barcode...
What does error code 5C00 mean (Canon Pixma 9500 Mk1)
thats code indicate that your refill ink pad full, you need to replace that pad, buy replacement from canon supplier.
Apr 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
I would like to use my magellan roadmate 800 in europe. I have heard there is an unlock code. Do you know what it is?
I am looking for the same thing. Were you ever able to find the unlock code? Magellan said they can no longer give it to me
Nov 02, 2009 | Magellan RoadMate 800 GPS Receiver
Error system on the display when I rebooted nokia 9500
hi there try this reset code for a nokia communicator phone like your 9500 just enter this code *#7780#
Feb 11, 2009 | Nokia 9500 Communicator
PSC MAGELLAN 9500 (202020211120103a) Fixed Mount Logo
203 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
