Question about Linksys WRT160N Wireless Router
Using WRT120N, wireless connection drops intermittently. Problem is not the modem - connectivity is stable when ethernet cable is directly plugged into the computer. How do I resolve the intermittent dropping?
I had a similar problem. I live in an apartment complex and there are many wireless networks all competing with one another. I changed the channel on my router to Channel 8, and have had no further problems. The default channels for most home routers are 1, 6,and 11. So, most users just power up their new routers and are up and running without realizing that there maybe 15 other routers in range on the same channel that are interfering with one another. You can download a trial version of PassMark Software's Wireless Mon application to see which channels are heavily used at your location. Then pick one that is ideally 2 channels away from any heavily used channel and set your router to this channel.
Posted on Jan 08, 2011
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
My linksys router WRT120N is having power light stable but no other lights are neither blinking nor stable!!! need your help
At power up the device runs a self test, it take a minute or so. What is it connected to, what is sending the signal, a cable modem, DSL, etc.? If you have cables runing from the Cable modem or whatever, to the linksys, try another cable, OR, reboot the cable modem, unplug, remove battery, if applicable, remove power from the WRT120N, Insert battery into the modem, plug in, wait for the self test, plug in the Linksys, wait for self test. Connect a ethernet cable from the linksys to the computer. Does it connect? Try to connect wirelessly, Does it connect? Is the Linksys secured with a passcode? If you push the reset button , and hold for a minute, in the rear of the device, it will reset the Linksys to default settings. Try to connect. Did the Linksys work at one time? Did you set it up? Is it on a surge protector? Have you had any Electrical storms? Surges? It may be bad, hard to say until you verify all the steps. Who is your internet provider? Have you verified that they are sending a signal? Comcast will verify ,by phone, that the signal is good and run check on the cable modem.
Nov 22, 2012 | Cisco - Linksys Wireless-n Home Router -...
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
Connecting My Cable TV Modem To Wireless Router
yes you can. you simply plug the modem into the input port on the wireless router and then plug which ever device you want to hardwire into the back of the wireless router. that's all :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 16, 2009 | Computers & Internet
PC losing connections (ethernet) with Belkin router
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
Oct 17, 2009 | Belkin (F5D7231-4) Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Intermittent DSL connection
see if the filters, is coneted well, if not, exchange it.
Sergio
Nov 24, 2008 | 2wire (1000-000057-000) Modem
Testing my RangeMax WPN824
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
There is a possibility that the router setting might set back to its default settings. you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code to avail their 1 time free technical support.
Jun 09, 2008 | NetGear RangeMax WPN824 Wireless Router...
2wire dropping xp pc
hello!
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
NetGear wireless router model wpn 824 v2
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
    1. Start your network in this order:
      1. Turn the modem power off.
      2. Turn the router power off.
      3. Turn the modem power back on. Wait two minutes until the lights are stable.
      4. Turn the router power back on. Wait one minute until the lights are stable.
      5. Turn the computer power back on.
    2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to http://kbserver.netgear.com.
    3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
    4. Click OK. This logs you into the router.
    5. Click Setup Wizard, on the left of the router settings page and set up your router
    6. that would fix your problem..
Nov 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
Linksys WRT160N Wireless Router  Logo
1,472 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
