Question about Kenmore 73952 Gas Dryer
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
  • Kenmore Master
  • 2,699 Answers
The motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Posted on Aug 05, 2010
  • Sal De Aug 06, 2010
    i meant at the end that you have to change out the motor or get a new dryer if the dryer is in rough shape
    how did you make out,was it the motor?
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
My basement got flooded and my kenmore elite now don't want to start
you have a bad motor,i live in boston and we had some floods here,every dryer i checked that got wet needed new motors,the washers were fine,check with a meter to see if power is going to motor,if it is and it's not starting you know it's the motor.good luck.the motors are easy to change out yourself
Oct 12, 2010 | Kenmore 63942 Dryer
My basement flooded and now my dryer won't start..What should I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor got wet and is no good anymore...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2010 | Kenmore 500 6953 Dryer
The basement flooded and the dryer is making only a humming sound
i would try to spin the tub sounds like the motor might have locked up
Jun 02, 2010 | Estate TEDS740JQ Electric Dryer
I have a Kenmore 600 electric dryer. The basement flooded and the dryer was in approximately 6 inches of water. I've removed all the water from the cabinet and let it sit for 2 days to completely dry out....
Sorry to say but water ruined the motor. You can test it again by pushing the start button and at the same time spin the motor. If the motor starts that will tell you the start windings in the motor are bad. The motor would have to be replaced.
Mar 20, 2010 | Kenmore 63942 Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Frigidaire front load washer
Did this cause the machine to stop work? Did something get burn? If its just that it got wet - just plug it out and do not start using it right away give it some time to drip dry and if you know how open it up and have a look to make sure no water is inside.
Regards
Sep 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer won't start
hi thanks for the question theres a small thermal fuse located under the door behind the panel to get access remove front bottom panel 2 screws at bottom of panel and on the air duct to the left theres a small thermal fuse check it for continuity if bad replace thanks the appliance doc
Aug 20, 2008 | Kenmore 62872 Electric Dryer
Kenmore 73952 Gas Dryer Logo
134 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
