Question about Maytag Neptune MAH5500B Front Load Washer
My magtag neptune front loader washer model #MAH4000AWW serial #53330348YM just did the strangeset thing. The cycle completed set at colors, cold, max extract. I heard it beep to indicate that the cycle was done and the door is unlocked. Before I could go move the clothes to the dryer, I heard water running again. The washer was filling up while with super hot water and the dial was still setting at the end of the cycle that it just finished. I cannot get the washer to spin without the water continuously running hot. If I turn it to any point in any cycle the water immediately runs hard and very hot. Any suggestions?
catriver
  • 878 Answers
SOURCE: Maytag Neptune MAH4000AWW noises
Cd, Im not so sure that the wax motor would have anything to do with the problem. If the door is locking, I would say no. It sounds more like it is dropping a phase on the motor. On this model the motor still can run under light loads when one of the 3 motor phases is not working. When you mentioned grinding noise, if the motor is not functioning right, (loosing a phase) it will be noisier and make a growling noise. Im wondering if that is what you are hearing. We can rule out the motor or motor controller but you are going to have to do some tests with an ohm meter. This will also require removing the door, front panel to get at the motor controller. The motor and motor controller can be expensive so you need to decide whether you want to invest money into this Neptune. You decide and post back. I can walk you through the tests. Catriver.
Posted on Sep 24, 2007
jsrock516
  • 5911 Answers
SOURCE: Hot water fill problem
Replace or clean your water inlet valve. It appears that the hot water solenoid has either become clogged, or had failed. You can find a replacement at repairclinic.com. Type in your COMPLETE model number in the Search window and there will be two of them located under the "Water Valve/Float" heading. Depending on WHICH type of valve you have, a replacement costs between $28 and $74. Refer to the part illustrations to make sure you are ordering the correct part. If you require assistance in accessing the inlet valve, let me know. I hope this helps you.
PS If you attempt to clean the valve, you will need to turn off the water supply and disconnect the hoses. Check the inlet screens for sediment or debris.
Posted on May 28, 2008
  • 30 Answers
SOURCE: what will the Max Extract button do?
The max extract button will do an extra spin to get any & excess water out of the clothes. It is a good thing to keep on to help cut down on drying time. If you find standing water in the washer, it is possible the hose is NOT in the correct position.
Posted on May 03, 2009
  • 8 Answers
SOURCE: what does the max extract feature do
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
Posted on May 15, 2009
  • 530 Answers
SOURCE: I have a Neptune front loader that now spins slow
does the door lock? if the answer is no then you have a blown resister on your main control board R11 and the reason it blew is your wax motor on your door lock is binding up. you need a new control board and wax motor.
Posted on Jun 15, 2009
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a burned out resister which I need to replace.
R11 = 3.9 K ohm 1/4 w If Q6 burned,change by NTE5657 ( 600v)
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH5500B Front Load Washer Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
