Question about Lowrance Boating
Need transducer for lowrance x17 - Lowrance Boating
5 Suggested Answers
Editor925
  • 285 Answers
SOURCE: Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
Posted on Mar 29, 2009
Editor925
  • 285 Answers
SOURCE: My Lowrance X-51 is not reading the depth sitting
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Posted on Aug 01, 2009
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
I turn my power source on and my screen flashes like it's not reading anything from my transducer but the transducer is new.
Has this unit worked in the past, or are the transducer and the unit itself new? Is this a Lowrance LMS-240 as indicated before your question?
Please let me know and I can help you out here.
Thanks, just reply here,
Tim
Oct 31, 2010 | Lowrance LMS-240 GPS Receiver
My Lowrance X-51 is not reading the depth sitting still of running . Do I need a new transducer ?
Jul 31, 2009 | Lowrance Boating
Hope that helps!
Mar 29, 2009 | SI-TEX Boating
I need operator's manuels for 2006 X17 (GPS unit?
http://www.lowrance.com/en/Downloads/Manuals/
Follow this link, then scroll down to your selection. It will download as an Adobe file.
Triton72
Mar 27, 2009 | Lowrance Boating
Boating Logo
69 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
