Question about RTO Time Mark Signaline Timer 98a00302-07 362-120v-.1
Looking for new timer or direct replacement for model 368-120v-.1sec timer and model 360-120v-1 sec signaline
Sunbeam mixer only runs 5 sec and stops. Same on all speeds.
that is timer/capacitor... if under warranty - get it replaced, otherwise - you are ready for new one...
as you did not give type and model, i cannot even "questimate" if it is worth repairing or throw it directly to the rubbish bin, do not collect $200.00 just pay them...
general rule is that below $50.00 do not bother repair...
hope this short info will help you - do not forget to vote...
Feb 01, 2015 | Sunbeam Food Mixers
Its a Double French doors pull out freezer on bottom, model number GFSS6KKYSS..my brother has plugged it back in after defrosting all the ice and we can't hear the fan, apparently not working yet? Is this...
On a regular fridge there is a timer located at the back of the fridge that activates the auto defrost on and off during a predetermined cycle. The timer provides power to an electrical heater (black cable) curled around the freezing elements, this action defrosts the cooler. This timer has an unusual rotating shaft on which a screw driver is used to rotate it and it is designed that rotation can only be in one direction. Look at the rear of your fridge and try to locate this timer, it is normaly mounted on the edge of a side panel near the coils.
Once you have located it , use a screw driver that fits the groove of the rotating shaft and rotate it in the allowed direction (as you can only turn it in one direction) the fan should the run, if not, slowly continue rotation 360 degrees and until it does . IT IS POSSIBLE THE TIMER IS DEFECTIVE...REPLACE IT WITH IDENTICAL TYPE AND MODEL. This should be the cure to your problem. Good luck.
jam
Oct 10, 2017 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
Brake does not work
with these saws, the motor fan comes off and there is a nut to turn to close the gap in the brake.. use 0.10mm as a guide..should stop within 1sec/ blade " diameter..eg, 10' blade stops at about 10 sec.
Jan 06, 2012 | Delta Radial Arm Saw
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
How do i set the timer?
On the back of the camera, on the botton directional button, the one that looks like a cross, press the "down" button, which has a clock on it. When you take a picture, you have approximately 10 secs before the camera will blink for 2 secs and take a picture. You can cancel the timer using the same procedure.
Jul 14, 2010 | Olympus ? 1030SW Digital Camera
Turning the power on causes the screen to display ENVISION for approx. 1sec.and it goes out and stays out. Switching a display signal on through an A-B switch gives approx. a 1sec. display time that does...
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
Jun 11, 2009 | Envision EN-7220 17" Flat Panel LCD...
How do I use 360' lens on my Canon G9?
The C1 & C2 settings are for "Custom" settings. You'll most likely want to set your camera either to "P" or "Auto" mode.
To have it delay for 10 seconds and take 3 shots, press the "Menu" button and then scroll down to "Drive Settings". Then, choose the following settings:
Self-Timer: "C" Delay: 10 sec. Shots: 3 shots
Then, press the "Func./Set" key to lock in the change. Next, press the custom timer button on the back of the camera and then choose the "C" timer using the directional keys. Then, press teh "Func.Set" button.
Lastly, set up your camera, press the shutter release, and the timer light should start blinking. 10 seconds later, the camera will take 3 photos in succession.
Hope this helps!
Mar 10, 2009 | Canon PowerShot G9 Digital Camera
Agitator drum only rotates in one direction
yeah it sounds like the programer has failed this part is expensive
shaun
Jan 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22924 top load
timer most likely suspect ..not sure of timer cost sears price usually 110-160 may find local parts place with cheaper price for part number remove console end caps remove screws underneath roll console up and back number on timer beside fsp or just go to sears.com click on parts link type in washer model # look for timer
Sep 04, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool AFG 7080 Freezer - Relay noises
It sure sounds like you have a problem with the board. It may just be a dry joint or a faulty component. Normally one would replace the board.
Nov 01, 2007 | Freezers
RTO Time Mark Signaline Timer 98a00302-07 362-120v-.1 Logo
41 people viewed this question
Top RTO Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
