Question about Konica Minolta magicolor 5430 DL Laser Printer
How do you reset your Konica Minolta 5430dl fuser life
  • 214 Answers
SOURCE: konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
Unplug the power cord and plug it in, then turn
OFF and ON the Power Switch.
the PWB-A may be faulty.
Posted on Jun 19, 2008
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
how do i reset an imaging unit on a konica c252
Posted on Dec 22, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
the fuser must be a fast blow 60mA, otherwise it will not work.
Posted on Apr 19, 2009
Suricatta
  • 92 Answers
SOURCE: need to reset the fuser counter
Hi there.
Download Service Manual here: http://nodevice.com/manual/Konica_Minolta_QMS_magicolor_7300_Service_Manualpdf/get690.html
and follow the instructions.
Regards.
Posted on Jun 24, 2009
How to reset the counter for my fuser unit on my Konica Minolta c552 copier
Utility/Counter, Details, Stop 00 Stop 01, (Password if required 92729272) Counters, Life,, New Release, Open the front door (Not the Toner Door), Select Fuser or Transfer Belt, and press the Start Key. Then exit all the way out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 26, 2015 | Konica Minolta Office Equipment & Supplies
How to clean up dirty printing?
REPLACE THE FUSER, IMAGE UNITS and transfer belt
Jun 16, 2014 | KONICA MINOLTA magicolor 5430DL
Magicolor 5430DL firmware
located at a secure Konica Minolta web site seem that Konica Minolta protects their Copier/printer firmware, available to only Konica Minolta dealerships and KMBS, need a tech
Feb 15, 2014 | Konica Minolta magicolor 5430 DL Laser...
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
How do i load a firmware upgrade on a Konica Minolta 5430DL
it requires some firmware files and another software, which you cannot get easily.so its better to call konica minolta's representative.
May 19, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL second tray - print dialogue
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Nov 08, 2009 | Konica Minolta Magicolor 2530 DL Laser...
How to increase the drum life of Konica bizhub c250
Forever to change the OPC drum and drum cleaning blade change the reset fuser(0,80A fast fuser).and the copier machine it work 60000 copies.
Sep 27, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
240 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
