Question about Broan-NuTone VX550 Bagged Central System Vacuum
I have Nutone VX550C. Motor runs intermittently (cycles on and off rapidly--the light on the handle is blinking furiously) when I use the on/off switch on the hose. This happens at all of the wall connectors, so suggests a hose contact problem. Motor runs continuously when I turn it on at the switch on the wall unit.
  • bheronman Aug 05, 2010
    My goal is to find out whats causing this and how to fix it. Also, does it do damage to run the vacuum under these conditions? Thanks and Regards, Rich
  • bheronman Aug 06, 2010
    YES, HELPFUL ANSWER. I WILL CHECK OUT MY OPTIONS.
  • 3,083 Answers
The unit does have a switchs the PVC outlets, and it sounds like the hose mech to operate the switches is broken, and intermittently making contact. A replacement hose would likely fix the problem. Looked them up on the net, and they're not cheap. Here's one site that offers free shipping, at least:
http://www.centralvacuumplanet.com/nutone/hoses.htm
Good luck to you, thanks for using FixYa, and hope this gets everything working again!
Posted on Aug 05, 2010
Is there any known do-it-yourself fix for the nutone vx-550 overheating problem?
there is a way to do it, yes. However, are you sure that the PC board inside is not what is causing the problem?? I mean, are the lights on and function normally when you turn the switch on or off??
If so you can proceed to bypass the two thermal cut offs located on the field coil on both sides of your motor inside. Yes, it can be done without taking the motor apart.
Also, move the other thermal next to the motor and attach it to the housing near the back of the machine. DO NOT remove it unless you absolutely need to. IE test the unit and let it run for approx 20-25 mins. if it does not shut off there is no problem with the last thermal cut off. If it shuts down within 5 mins, take it out too. It could be faulty now.
Good luck,
Mark
Nov 11, 2010 | Broan-NuTone VX475 Bagged Central System...
Nutone CV353 does not shut off, think it is the relay board
You probably have a stuck relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Take the unit to a local vacuum repair center for service.
Jun 26, 2010 | Broan-NuTone CV353 Central Vacuum
Have a nutone CV-450. Suction is gone at the
The first thing to do is to disconnect the pipe coming into the unit. If there is suction there than you probably have a break in the line. If there is no suction when you disconnect the pipe coming into the unit than it is most likely the motor gasket. This gasket can sometimes get sucked into the motor causing problems. Remove the lid to the central vacuum, than disconnect the motor, you should be able to tell if maybe the gasket has been off center or if it has been sucked up in the motor.
Dec 13, 2009 | Broan-NuTone CV450 Central Bagged Central...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Nutone cv353 central vac blew up
My guess would be that the motor is done. Impossible to diagnose for sure without seeing it of course. If you were happy with the unit before the trouble, a replacement motor will probably run $250-$300. If you are interested in a new unit, shop around. There are definitely better designed and more powerful units out there, although some of them can cost quite a bit more than $300. Good Luck!!
Dec 14, 2008 | Broan-NuTone CV353 Central Vacuum
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
Aug 09, 2008 | Broan-NuTone VX475 Bagged Central System...
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Jun 22, 2008 | Broan-NuTone CV450 Central Bagged Central...
Nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
Mar 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone VX550 Bagged Central System Vacuum Logo
83 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
