My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does not spin. Help on what this is and what's the best/ fastest/ cheapest/ easiest way to fix? THANKS!
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Posted on Sep 27, 2010
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
It started out not spinning. The lights would
kenmore portable washer will fill with water when button pulled out it just hums and occasionally tries to start.
Jan 30, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer won't spin or agitate
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
May 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer will not fill with water.
YOUR INLET WATER VALVE ON THE BACK OF WASHER HAS FAILED,HAVE YOU TRYED IT ON COLD ONLY,HOT ONLY TO SEE IF ONE OF THE VALVES WORK?IF NOT YOU CAN GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND YOU CAN ORDER THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Aug 02, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
No-spin and noise
ok first it sounds like something is stuck in your drain pump first if you have a shop vac then vac out the water through the drain line then tape the lid shut and lay the washer on its back to service also on the front panel on the inside will be a tech sheet there good luck
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
