Question about Regina RG3100 Vacuum
I have a Regina bagless vacuum and do not know how to change the belt
How do you change a belt on a dyson 07
You will need a spicial belt tool to change the bet on this unit. you can find it on ebey under "dyson spicial bet tool" do not try to use your hands. The belt is very tight and you can hurt your fingers if you get them stuck. let me know if this helps.
Oct 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
Changing belt
you have to take the top offthen there should be a black cover that comes off also that will reveal the belt shaft
Jun 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt
Please go to this link on my business web site for instructions on changing your belt: http://www.sewvac1.com/Hoover_U5162_900.pdf
May 07, 2009 | Hoover Fold Away U5162-900 Bagless Upright...
Bags and belts
hoover H bags work and Royal 4 &5reg. housekeeper belts work.Bought a piece of in. foam and cut it to fit my regina. Haven't found the hepa filter yet. I can't believe they just quit making these items!! Thanks for any help you have given me.
Aug 19, 2008 | Regina RG3100 Vacuum
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Regina 12amp bagless vacuum cleaner
i don't know about this particular model, but if you did opperate a full vacuum cleaner until it got hot and went off on it's own, this means you might have overloaded the motor and blown the protection fuse. in this case, you might have to change it. refer to the owner's manual about overload protection.
Mar 30, 2008 | Vacuums
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Regina RG3100 Vacuum Logo
62 people viewed this question
Top Regina Vacuums Experts
Marvin
Marvin
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
