Question about Yamaha RX-797 Receiver
Yamaha powers off while playing a and b channels @ the same time
  • 53 Answers
The combined resistance of both pairs on at the same time causes more current to flow and so on loud music is likely to be making the Yamahas protection circuit trip out.
If you really need to use all 4 of these speakers consider wiring them up through a seperate swicth box that does it in 'series' rather than the 'parallel' method Yamaha use.
AW
Posted on Sep 04, 2010
Yamaha 235 right speaker does not play. Sound only from the left speaker. The same problem exists with headphones..
Sounds like you have lost your power output to the right side. Should be able to fix if you have wiring diagram and find component that powers right channel
Dec 25, 2017 | Yamaha Audio Players & Recorders
Sometimes only one channel plays when playing CDs or DVDs. Jiggling the input knob will at times cause both channels to operate. This unit is a Yamaha RX-770 that I bought new. Thanks!
It sounds like you know what the problem is. Get it fixed.
Or try this temporary fix.
Or turn it off and manually operate the selector and all controls a thousand times to wipe the apparent oxides from their contacts.
Jul 06, 2011 | Yamaha RX-770
Yamaha HTR-6030. Using two optical cables for cable tv and xbox/wdtv-live box. On some cable channels and also on my xbox, no sound will play if I use it "straight". If I use "simulated...
Please don't panic and think that there is anything wrong with your Yamaha receiver. A lot of people are having this problem with set top box reception. Time lag / phase differences caused by satellite transmission can make your Receivers digital decoders go nuts !!!.The working principal is too complex to explain on this page. I have had clients call up and say on some channels only one speaker works in a 5.1 setup !!!!.You noticed DD and DTS signals are working fine.
Mar 12, 2011 | Yamaha HTR-6030 Receiver
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
Apr 13, 2010 | Yamaha HTR-6030 Receiver
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32 http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/mg12_4fxe.pdf
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
Mar 31, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
5. chanel and stereo sp.B at the same time
The yam 361 can not play A and B speakers at the same time you need to buy a switch box so you can select one pair or two pairs of speakers.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Output volume varies, with loss of bass and clarity
This sounds more like a power supply problem. I would have the voltaeg regulators checked along with the filter capacitors in the power supply area.
Dan
Aug 29, 2008 | Yamaha RX-V870 Receiver
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Open Questions:
See all Yamaha RX-797 Receiver Questions
Yamaha RX-797 Receiver Logo
87 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
