Question about Amprobe R-115S Remcon Relay Switch
I have a Remcon - R115 relay - - I have been told that they are no longer made - - must go to the R115S or the R120S. True? Options?
    Problem Solver:
  • 11 Answers
Yes, you need to go with the 115S (the 120S is the closet light - 2 wire - product.
Options GE RR7 relays, but they have no integral transformer
(also you could ebay for an old remcon device ( the one that the amprobes replaced :) )
Hope thi shelps
Posted on Feb 16, 2011
I had a repairman out and he told me I needed a circute board for the tv,but this part is no longer available and to junk the tv.
Most Repairmen are board level technicians, what you need is a component level tech, Keep looking, they are still there. I was a component service man for 25 years and a service manager, I should know.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 21, 2013 | Toshiba Office Equipment & Supplies
My circuit has separate transformer, can I use r115s? Are there modifications that need to be made?
Likely it will damage it; the Remcon/Amprobe will work with the existing switches; just don't connect any wires from the external transformer
Feb 07, 2012 | Amprobe R-115S Remcon Relay Switch
I have two ceiling fan light fixtures on a remcon light switch and it turns off right after you let go of the switch until it warms up. You have to keep pushing the switch, or hold it down for an extended...
I believe that RC-120 is a 2-wire closet light control relay that is designed only to turn on while switch is closed - Do you mean 120 or is it a 115 (three wire on-off latching relay)
Jan 13, 2011 | Amprobe RC-120S Remcon Relay Switch
Have two ceiling lights contolled by a R115s relay and the lights will not shut off. Have replaced the switches and the problem still persists, can I check the function of the relay prior to replacement?...
hi
it sound that the relay is stuck on the on position( meaning that light will not switch off ) if that is the case a new one is required. a relay can be tested by applying the correct voltage to the coil side of the relay this will close the relays allowing the current to flow through to light up .
suggest to replace the relay
Jan 04, 2018 | Amprobe R-115S Remcon Relay Switch
It runs for a little while and quits
ready heater runs for a minute then shuts off
Dec 10, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have two roof mounted master cools, I was told that these are no longer made. Is this true?
Yes it is true they are no longer made. But parts are still available for them as many HVAC units can swap parts. and you do not even have to go OEM to fix it if it is broken. A lot of Newer techs do not know how to work on these units
Apr 18, 2009 | Mastercool 67471 Evaporative Cooler Air...
Marantz CDR500 has record bay which no longer opens. I was told some time back that this is not repairable and that Phillips, who made the drive, no longer makes them so it is essentially a total loss. ...
This is a tricky one, because from the view of an authorized Marantz servicer, the replacement "part" is probably the entire drive which may no longer be available. It is possible that the true problem is that the main drive belt is slipping. In that case, replacing the belt will fix the problem. As long as the unit is not under warranty, any service shop should be able to attempt a repair. They can not make it worse and perhaps can resolve it cheaply.
Dan
Apr 06, 2008 | Audio Players & Recorders
Amprobe R-115S Remcon Relay Switch Logo
787 people viewed this question
Top Amprobe Electrical Supplies Experts
Steve
Gary Meyer
Gary Meyer
Level 1 Expert
Franco Pinto
Are you an Amprobe Electrical Supply Expert? Answer questions, earn points and help others
