Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Agitator belt failed in my Hoover F5853-900 Steam Vacuum Cleaner. But can not remove bottom Cover .. have removed top cover and two screws from the bottom Cover. The smaller Cover is glued to the large Bottom Cover. Need help.
    Genius:
  • 1,478 Answers
Unscrew the plate. check if there is any screws at the bottom, if none, exact little pressure to pull out the bottom cover. At this point you should be able to see the broken drive belt along with the two drive bars. Remove any debris from the vacuum head. Untangle any long threads wrapped around the beater bar. These only put more strain on a drive belt, so keep this area of your vacuum clean. Slip the new drive belt on the beater bar. Connect it with the drive shaft. You may need to use the screwdriver to stretch the belt enough to get it over the two shafts.
Make sure the beater bar turns freely with the new drive belt attached. Put the plate back over the beater bars.
Take care.
Posted on Aug 05, 2010
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
How to install new belt? doughewines@yahoo.ca
First lay the vacuum on it's front side and remove the bottom plate covering the agitator. It is usually held in place with 2 tabs,although there may also be screws. The upper cover can be removed next. Pry it loose by inserting a screwdriver along the outer sides. There are usually small arrows molded into the base indicating the places where tabs hold the cover on. You may want to pull off the heigth knob on top of the cover first. Place the new belt ( #38528040), around the agitator, and push the belt through the opening in the base. Next the belt must be stretched around the motor shaft. This will require some strength, as the belt must be stretched a fair distance. It is best to use a strong screwdriver as a lever.
Mar 21, 2011 | Hoover U5227-930 Elite Upright Vacuum
I have a Hoover Model #U6430-900, Self-propelled Ultra Wind Tunnel Upright- I am sure the actuator arm- for the self propelled function- has broken. My question is how do I remove the plastic cover on top...
Hi There,
Here's a step by step guide that will explain in detail how to remove the top cover on your Hoover. The repair was written for a different problem then one you're experiencing, but you can follow along step by step to see how you can remove the top cover.
If you haven't already purchased the actuator arm, here's a link for you to the part on Amazon
Hoover Windtunnel Self-Propelled Windtunnel Actuator Arm
Here's the repair guide:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt2_bing.gif rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover.
Once you have removed the top cover, here's a link to a guide that will show you how to replace the actuator arm itself:
http://vacfactsblog.com/2009/12/how-to-change-actuator-on-hoover-self-propel-vacuum-cleaner-step-by-step/
I hope that this information helped you fix your vacuum cleaner. If you have any follow up questions, or need clarification on something, please feel free to use the comment box here on the Fixya repair page, and I'll be happy to answer any of your questions.
If this was helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated by the Fixya community if an answer was helpful.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Ultra U6430-900 WindTunnel Bagged...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover upright model u5095-930 belt change
I couldn't find your specific model but this may be similiar to another that you have to position the new belt around the agitator (beater bar) on the bottom of the vacuum, replace the cover, and then turn the vac over and remove the TOP cover to lift the new belt up and place it on the motor shaft/pulley. The new belt may require some effort to pull it over the pulley.
Hope this helps.
Oct 29, 2008 | Hoover Vacuums
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Need to change a belt on a hoover encore supreme upright vacuum
I'm more specialized in Kenmore vacuums, but I believe there should be 2 screws at the bottom of the vacuum. You will need to remove these 2 screws to be able to remove the bottom cover. Once the bottom cover is removed, you should be able to access the belt and agitator.
Mar 07, 2008 | Vacuums
Hoover u5227-930 Elite Upright
I figured it out! The key is removing the "head" that covers the headlight - use a flathead screwdriver to pop it off.....then the belt connects from the agitator to the motor pulley. Phew!
Jan 20, 2008 | Hoover U5227-930 Elite Upright Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
51 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
